Vizio V470L Turning off When Using OTA Antenna
  • leaperk
    • Aug 2014
    So my Vizio TV started to have issues where when using the tuner watching OTA channels that after 10-15 minutes the speaker will make a high pitched noise and the screen will go gray with green and red dots and than TV will shut off after five to seven seconds. I can watch HDMI sources without any issues, has anyone see or experienced similar behavior?
  • Hondaman
    Single-channel antenna?
    by Hondaman
    Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
    I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
    Years ago I made a "T"...
    11-18-2024, 01:14 AM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • Chaks
    Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
    by Chaks
    TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
    The specs says ...
    High antenna efficiency 868MHz ISM Band
    5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
    The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
    1. Should I Fix it with a glue.
    2. Should I fix it with a double side adhesive tape
    3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
    12-09-2024, 11:06 AM
  • SolomonMan
    Antenna...
    by SolomonMan
    All,
    I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
    There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
    Since we moved in, 8 years ago,...
    10-05-2023, 02:37 PM
  • Hondaman
    Gray-Hoverman antenna
    by Hondaman
    Hello all,
    Recently I'm upgrading my Gray-Hoverman antenna. Original design. I cannot use a "double-stacked" antenna because of attic space. I do not wish to mount anything to my chimney.
    I am using a separate antenna for WHAS Channel 11 (they are using RF Channel 11, 198-205 MHz). I replaced my 29-inch "T" antenna made out of #12 or #10 wire. I made a 58-inch "T" antenna out of 0.25-inch copper tubing. Hooked it up with a matching transformer to the 75-ohm coax going to my TV. I held the "T" antenna up against my ceiling, less...
    10-16-2021, 05:28 PM
