No backlight, with sound Samsung lcd LN46B640R3F
+ More Options
Posts
  • sandersen
    • Jul 2014
    • 19
    Looking for help on LCD tv. Tv was working fine then all of a sudden all goes dark. Sound still works can still see image on screen with flashlight test, just no backlight.
    So far I have checked fuses at power supply both were good,all capacitors looked good as far as I could tell (no bulges). Tried unplugging the main board from the power supply to force the backlight on. Backlight did not turn on. Jumped the SB pin and PS pin at the power supply and checked voltages at all the pins. All looked good 5.1V pins read 5.21V, 13V pins read 12.94V. The pins I'm not sure about are INV-ON read 3.8v, I-PWM read 0V, E-PWM read 5.23V and 5V DET read 0V.
    Any help would be appreciated.
    Samsung LN46B640R3F
    Power supply BN44-00265B
    Re: No backlight, with sound Samsung lcd LN46B640R3F
    Can we see the whole back side of the TV so we can see how all the boards are connected together?
    • sandersen
      • Jul 2014
      • 19
      Budm
      These are the pictures of the back. Left side first.
      • sandersen
        • Jul 2014
        • 19
        Here is the right side. Can't post all at once?
          OK, is the fuse F1801 OK? This fuse feeds the b+ to the Inverter circuit.
          Also check the DC Voltage right at the two legs of the main filter caps (the two 4501VDC caps laying on their side), it should have around 360~400VDC when TV is ON.
          http://www.shopjimmy.com/samsung-bn4...er-supply.htm#
          Sch in PDF.
          • sandersen
            • Jul 2014
            • 19
            These are the two fuses I checked. Both had 5 ohm resistance so they are good. The caps that I measured are cp802 and cp803 both, with a jumper on ps and sb, measured only 62VDC.
            First fuse.
            • sandersen
              • Jul 2014
              • 19
              Here is the second fuse on the top left. The two caps I measured are the on the right.
                "These are the two fuses I checked. Both had 5 ohm resistance so they are good"
                Fuse should have the same resistance reading as when you touch the two probes of your meter together. 5 Ohms reading on the fuse is not right.
                "The caps that I measured are cp802 and cp803 both, with a jumper on ps and sb, measured only 62VDC." Are you measuring RIGHT AT THE TWO LEGS OF THE CAPS as instructed? Just remember, you are making voltage measurement in the primary side of the circuits, you cannot use chassis as the ground ref point for the lack lead of the meter.
                Based on what you indicated for the voltage reading, you must have used the chassis as the ground ref, unless your meter is bad.
                • sandersen
                  • Jul 2014
                  • 19
                  When I put my leads together I do read .5 ohms. Also checked in diode mode there is continuity.
                  • sandersen
                    • Jul 2014
                    • 19
                    You are correct I did use chassis ground. Should have measured voltage across the caps. Don't know what I was thinking???
                    • sandersen
                      • Jul 2014
                      • 19
                      Will check voltage correctly tomorrow. Thanks for the help.
                      • sandersen
                        • Jul 2014
                        • 19
                        Measured correctly this time. I measured 384 VDC on both capacitors.
                          OK, that is good, it means the PFC Voltage booster is good and you do have invr_ON signal so now we have to look at the inverter circuit section next.
                          • sandersen
                            • Jul 2014
                            • 19
                            So the inv-on voltage when the sb and ps pins are jumped should be at 3.8 VDC . I assumed it should be 5.1 VDC?
                            • sandersen
                              • Jul 2014
                              • 19
                              Went ahead and measured the voltage at the ena pin on lx6503 (second to last pin on the left side of the picture). Voltage was 2.56VDC ref to chassis ground and the same voltage was on cap labled c1837.
                                > 2V = ON, <1V = off, so you are OK, it will not be 5V due to voltage divider in the circuit.
                                • sandersen
                                  • Jul 2014
                                  • 19
                                  Sorry picture is rotated. Second pin from the top, on the right is where I measured.
                                    What do you get on the VCC pin1? Also on drive 1 and drive 2 (check with DC and AC mode on the meter).
                                    Also check the capacitance of C1804 (0.68uf 500V).
                                      • 31044
                                      can you remove the big black plastic cover on the lamp panel and take a foto pls.
                                      • sandersen
                                        • Jul 2014
                                        • 19
                                        @stj here is the inverter board
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
                                        • henry21347
                                          Samsung LN52B550K1F no backlight has picture has sound
                                          by henry21347
                                          Hi I have a samsung LN52B550K1F LCD TV. There is no backlight but I can see a picture under a flash light. The sound is playing as normal. I have attached the pictures of the boards.
                                          With my laptop connected to HDMI4 port, I tested the voltages of the connectors:
                                          Power board (BN44-00267B) to main board (BN97-03035M) connector (CN801):
                                          5V_DET 0.1V
                                          E-PWM 2.77
                                          I-PWM 0
                                          INV-ON 0.05
                                          13V 12.81
                                          5.1V 5.15
                                          SB 5.2V
                                          PS 1.22
                                          SYNC 1.74
                                          Power board to LED driver board (SSB520H18V01):
                                          VCC...
                                          12-23-2022, 12:29 AM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Pwtzz
                                          Samsung UN55TU7000 no picture but have power, backlight, and sound
                                          by Pwtzz
                                          I obtained this Samsung UN55TU7000 and want to save to save from going to the dump. It has backlight when I turn on the TV, it stays lit, and when I click the menu on the remote the backlight blinks and has sound.
                                          I've search here and looked up pages after pages but I can't find the specific one. I'm only equipped with soldering iron and multimeter for now. I've found plenty of shorted caps in the right side panel (when looking in front of TV) itself since this Samsung has the T-con integrated. No short on the left side. The pattern of the shorted caps is as followed....
                                          11-09-2021, 11:19 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
