No backlight, with sound Samsung lcd LN46B640R3F
  • sandersen
    • Jul 2014
    • 19
    Looking for help on LCD tv. Tv was working fine then all of a sudden all goes dark. Sound still works can still see image on screen with flashlight test, just no backlight.
    So far I have checked fuses at power supply both were good,all capacitors looked good as far as I could tell (no bulges). Tried unplugging the main board from the power supply to force the backlight on. Backlight did not turn on. Jumped the SB pin and PS pin at the power supply and checked voltages at all the pins. All looked good 5.1V pins read 5.21V, 13V pins read 12.94V. The pins I'm not sure about are INV-ON read 3.8v, I-PWM read 0V, E-PWM read 5.23V and 5V DET read 0V.
    Any help would be appreciated.
    Samsung LN46B640R3F
    Power supply BN44-00265B
    Re: No backlight, with sound Samsung lcd LN46B640R3F
    Can we see the whole back side of the TV so we can see how all the boards are connected together?
    • sandersen
      • Jul 2014
      • 19
      Budm
      These are the pictures of the back. Left side first.
      • sandersen
        • Jul 2014
        • 19
        Here is the right side. Can't post all at once?
          OK, is the fuse F1801 OK? This fuse feeds the b+ to the Inverter circuit.
          Also check the DC Voltage right at the two legs of the main filter caps (the two 4501VDC caps laying on their side), it should have around 360~400VDC when TV is ON.
          http://www.shopjimmy.com/samsung-bn4...er-supply.htm#
          Sch in PDF.
          • sandersen
            • Jul 2014
            • 19
            These are the two fuses I checked. Both had 5 ohm resistance so they are good. The caps that I measured are cp802 and cp803 both, with a jumper on ps and sb, measured only 62VDC.
            First fuse.
            • sandersen
              • Jul 2014
              • 19
              Here is the second fuse on the top left. The two caps I measured are the on the right.
                "These are the two fuses I checked. Both had 5 ohm resistance so they are good"
                Fuse should have the same resistance reading as when you touch the two probes of your meter together. 5 Ohms reading on the fuse is not right.
                "The caps that I measured are cp802 and cp803 both, with a jumper on ps and sb, measured only 62VDC." Are you measuring RIGHT AT THE TWO LEGS OF THE CAPS as instructed? Just remember, you are making voltage measurement in the primary side of the circuits, you cannot use chassis as the ground ref point for the lack lead of the meter.
                Based on what you indicated for the voltage reading, you must have used the chassis as the ground ref, unless your meter is bad.
                • sandersen
                  • Jul 2014
                  • 19
                  When I put my leads together I do read .5 ohms. Also checked in diode mode there is continuity.
                  • sandersen
                    • Jul 2014
                    • 19
                    You are correct I did use chassis ground. Should have measured voltage across the caps. Don't know what I was thinking???
                    • sandersen
                      • Jul 2014
                      • 19
                      Will check voltage correctly tomorrow. Thanks for the help.
                      • sandersen
                        • Jul 2014
                        • 19
                        Measured correctly this time. I measured 384 VDC on both capacitors.
                          OK, that is good, it means the PFC Voltage booster is good and you do have invr_ON signal so now we have to look at the inverter circuit section next.
                          • sandersen
                            • Jul 2014
                            • 19
                            So the inv-on voltage when the sb and ps pins are jumped should be at 3.8 VDC . I assumed it should be 5.1 VDC?
                            • sandersen
                              • Jul 2014
                              • 19
                              Went ahead and measured the voltage at the ena pin on lx6503 (second to last pin on the left side of the picture). Voltage was 2.56VDC ref to chassis ground and the same voltage was on cap labled c1837.
                                > 2V = ON, <1V = off, so you are OK, it will not be 5V due to voltage divider in the circuit.
                                • sandersen
                                  • Jul 2014
                                  • 19
                                  Sorry picture is rotated. Second pin from the top, on the right is where I measured.
                                    What do you get on the VCC pin1? Also on drive 1 and drive 2 (check with DC and AC mode on the meter).
                                    Also check the capacitance of C1804 (0.68uf 500V).
                                      • 31090
                                      can you remove the big black plastic cover on the lamp panel and take a foto pls.
                                      • sandersen
                                        • Jul 2014
                                        • 19
                                        @stj here is the inverter board
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
