Panasonic TH-50PX80 killed by lightning strike, help me save her!
  • SluggerB
    • Aug 2020
    • 747
    • US
    Yes it's a 17 year old Panasonic plasma!
    I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front of the TV to turn off, it only turns off by pulling the power cord.
    Odd thing is, the TV was plugged into a surge protector, and literally zero other things in the house had any damage whatsoever. The clock on the microwave didn't even reset. This TV is the only thing that got damaged. So it might have not been electricity but the shaking that did some damage, who knows.
    Since there was a picture on the screen when it froze, I know the screen is still good, and it does seem to "turn on" so the power board seems to be working, so Youtube is telling me it is probably the main board? I opened the TV up and nothing on the main board looks out of sorts, no blown chips, no scorch marks or burn marks or anything, but I ordered a used board off eBay anyway and it will be here tomorrow, hopefully that fixes it.
    Any ideas on other things to check? I would really like to have this TV still working.
  • R_J
    • 9535
    continued from other thread, ... unplugging the tv for a day or two and see if starts to operate normally, based on your description it does seem like A board programming data is corrupt.
    • EazyBone
      • Jun 2023
      • 1330
      • United states
      Surge protector won't ever protect from a lightning strike just fyi. 6.21 gigawatts of energy ain't gonna be stopped by a tiny surge protector. (Thanks back to the future)
      • lotas
        • Jan 2016
        • 4601
        • Russia
        If something was connected to HDMI, then the HDMI hub on the motherboard could have been damaged...
        • SluggerB
          • Aug 2020
          • 747
          • US
          The TV set up is coax from wall -> cable box > HDMI out from cable box > HDMI to TV. There was also an Amazon Fire Stick in another HDMI port
          Thing is both the cable box and the Fire stick are perfectly fine. As is every other electrical appliance in the house. I would imagine if enough power went though either of them to damage the TV, they would have been damaged themselves. The lightning was nearby but not a direct hit on anything.
          Tried that, nothing. I swapped the cap I thought was bad out of the power board and same behavior, I plug the Tv in and it makes the normal relay click noises it makes when plugging in, I push the power on button on the remote and the TV makes the relay click noise that it makes when turning on, the red light is on at the bottom, I see some glowing and a lighter shade of black on the TV, but no picture at all, no response to the TV from the remote and the only way to turn the TV off is pulling the power cord. I think that means the power board is working and the standby voltage is working at least?
          I took the main board out of the TV today and gave it a visual inspection, everything look pristine on it so nothing obviously blew up. We'll see what happens when I put the eBay replacement in later tongiht/tomm, depending on when the FedEx guy shows up
          • lotas
            • Jan 2016
            • 4601
            • Russia
            And you touch its case (Analog Devices ADV7495B BSTZ-170), if it heats up a lot, becomes hot, then the problem is in it.
            • SluggerB
              • Aug 2020
              • 747
              • US
              I d not understand what you are saying
              I swapped the original 1900uf cap back on the power board and reinstalled it. The new main board showed up today and I put that in but th TV till doesn't work. It turns on but I get 12 blinking red lights on the front and no picture on the screen.
              • lotas
                • Jan 2016
                • 4601
                • Russia
                This is a chip on the motherboard (HDMI hub).
                • Ady2017
                  • Dec 2017
                  • 50
                  I once had a TV killed by a lightning strike back in about 2006. It was an old CRT TV and when I took the back off of the TV a number of the chips had exploded. There was that much energy that it had blown many of the chips into pieces. Like a fool, I left the TV on during the lightning strike to keep my cat calm but the sound of the TV exploding left the poor cat hiding behind the sofa shaking. Everything gets unplugged now. Time to treat yourself to a new TV my friend.
                  • lotas
                    • Jan 2016
                    • 4601
                    • Russia
                    Error code 12, sound problem....
                    • SluggerB
                      • Aug 2020
                      • 747
                      • US
                      So I disconnected all the wires and ribbon cables to rule out bad connections. Now, instead of getting 12 blinks, I am getting 1. This is with the original Power Board, with original cap, and new Main board. I tried reseating everything again, no dice. TV will turn on with remote press, then turn off and give a 1 blink code forever until you unplug
                      • SluggerB
                        • Aug 2020
                        • 747
                        • US
                        Where can I test that 5V STB to make sure it is there? I see no labeled test points on the power board
                        https://www.badcaps.net/forum/troubl...80u-no-picture has identical photos to all my boards so that is a reference.
                        • SluggerB
                          • Aug 2020
                          • 747
                          • US
                          OK, so I found .... something
                          Turns out the 5v STB test points are on the main board, not the Power Board. There are two points by where it is marked. I tested each, and they are reading 3.5v, not 5v. See the picture of the main board with two red circles, that's where I tested.
                          I followed the wiring where I believe the Power Board is supplying voltage to the Main board, and tested the red wire on that connector. It as well is testing 3.5v. See picture of Power board to see where I tested
                          Any ideas what could cause that 5v rail to drop to 3.5v?
ID:	3653593 Click image for larger version
                          • lotas
                            • Jan 2016
                            • 4601
                            • Russia
                            Service Manual....
                            • SluggerB
                              • Aug 2020
                              • 747
                              • US
                              Well I'm not the best at reading schematics, but Page 30 shows P7 as the STB connection between the power board and the Main board and it should be 5V but I am only reading 3.5. I do not see any 3.5V input to the main board from the power board either. So it seems the power board is outputting the wrong voltage
                              Edit: I just checked the STB again right now and it is at 2.6 mV. What is going on with this thing?
                              • lotas
                                • Jan 2016
                                • 4601
                                • Russia
                                And what voltage does the power supply supply on the original board produce? Maybe the new board is not working and has a problem with this power supply...​
                                • SluggerB
                                  • Aug 2020
                                  • 747
                                  • US
                                  This is the original power supply. I replaced the main board. The replacement power supply is in the mail but not here yet.
                                  I am hypothesizing that a power surge sent to much voltage thorough the power board and fried the original main board (which is why I got no functioning error messages) then the power board failed and now is not giving correct voltages to the replacement main board.
                                  • lotas
                                    • Jan 2016
                                    • 4601
                                    • Russia
                                    I meant to put the original motherboard back and what voltage will your original power supply unit produce on the STB?
                                    • SluggerB
                                      • Aug 2020
                                      • 747
                                      • US
                                      Ahh, gotcha. I will try that in a bit
                                        • 12196
                                        • U.S.
                                        You need to do testing, remove powerboard, check the underside for anything obvious. here's a few things to check Q151, Q171, D601, D602, D603, D607, D615, youtube is your friend for testing procedures if needed.
                                        • Bardou Kari
                                          HP EliteBook 840 G6 – no power after lightning strike
                                          by Bardou Kari
                                          I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                          – Charger is OK and 19V is present at the motherboard.
                                          – No charging LED, no fan, no reaction.
                                          – I don’t see any 3.3V or 5V near the coils.
                                          – Battery is unplugged.
                                          – I’m new to board repair but can use a multimeter.
                                          I added a clear photo of the board.
                                          Any idea where to start or what to check next?
                                          Thanks a lot for your help!...
                                          07-01-2025, 10:45 AM
                                        • karthur
                                          Samsung UN60EH6000 wont come on after lightning strike.
                                          by karthur
                                          We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                          I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                          When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                          Here is what I have checked.
                                          On the power supply board, 14pin connector:
                                          1 :12.7 Vdc
                                          3 :12.7
                                          5 :12.7
                                          7 :12.7
                                          9 :0
                                          11 :5.
                                          13 :5....
                                          11-01-2023, 06:18 PM
                                        • MrCreosote
                                          Lightning Strike: 55" TV dead: is display panel OK?
                                          by MrCreosote
                                          THE LIGHTNING:
                                          This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                          Very close and probably a very strong EMP.
                                          THE TV:
                                          No standby LED. Some voltage from PSB (not totally dead).
                                          But found a kit of ALL 4 circuit boards for $55.
                                          At first thought, this will fix my TV.
                                          But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                          08-16-2021, 10:27 PM
                                        • pbig
                                          advices for repairing Sony Bravia 32EX600 after lightning strike
                                          by pbig
                                          hi everyone,
                                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                          - from connector CN6150 (15 poles)
                                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                          06-28-2023, 02:43 AM
                                        • pfl
                                          ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                                          by pfl
                                          Hello Everyone.
                                          This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                                          It consists in :
                                          • a power board were the full H bridge class D amplifier and main power rails are located
                                          • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                                          Power rails are ok.
                                          human interface is working fine
                                          Input levels are...
                                          01-23-2024, 10:21 AM
