Technica M32/57G
+ More Options
Posts
  • sordids999
    • May 2013
    • 2158
    Technica M32/57G
    Hello got this tv today no standby light totally dead until I checked voltages,which voltage readings on the psu seem to be all over the place
    Any ideas ?
    Re: Technica M32/57G
    All voltages or only 5VSB?
    • sordids999
      • May 2013
      • 2158
      All of them tom
        OK, try unplugging power connector from main board and check 5V standby again.
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          are they stable voltages or fluctuating? stable but off voltage points to caps,fluctuating would point to a output diode,or startup cap
          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
          • sordids999
            • May 2013
            • 2158
            No voltages at all
              You should have at least one standby voltage.
              • sordids999
                • May 2013
                • 2158
                fluctuating multimeter
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  voltage on main filter cap?,should be around 320 DCV plugged in and power on
                    I'd be focusing on the small electrolytics on the power board's primary side - possibly a bad startup capacitor.
                    • sordids999
                      • May 2013
                      • 2158
                      Sorry my bad
                      +5v= 2.9 steady
                      +5v= 2.9 steady
                      +5v SB =4.1 but fluctuating
                      +5v= 2.9 steady
                      • sordids999
                        • May 2013
                        • 2158
                        Main 450v cap top left of psu reads 395v steady
                          Can you supply a close up picture of the power supply?
                          • sordids999
                            • May 2013
                            • 2158
                            Is that ok ?
                              OK, I'd try replacing C27, C2? (C21 maybe, just below C27), C19 and C18.
                              • sordids999
                                • May 2013
                                • 2158
                                Right replaced c27, c 18, c 19 the red standby light came on then went to blue but cut out again so I then went a changed c21, cs 30 but still the same
                                  Do you now have steady 5V standby?
                                  • sordids999
                                    • May 2013
                                    • 2158
                                    ok replaced all these as above still nothing but just turned it back on to test the 5v standby and now its working tv all good
                                    very strange didnt work first time i changed the caps ?
                                      I'd soak test it for a while - you might have an intermittent fault somewhere.
                                      • sordids999
                                        • May 2013
                                        • 2158
                                        To be fair i run out of 22uf 50v caps so took two from a old board (maybe its them)so ill order some more
                                        but thanks for your help tom again
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • psssst
                                          Yamaha TSX 120 Standby Problem
                                          by psssst
                                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                          03-01-2024, 07:25 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
