Panasonic TC-P60S30 - no standby voltage
  • BobbyMJ
    • May 2025
    • 12
    Hi All,
    Wanting to learn some electronics repair skills.
    I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
    So far I have found a blown cap on the main power supply board.
    After replacing it there's still no standby power.
    Poked around and found a resistor on the PSUB power supply board that measures open.
    An online resistor calculator shows this is a 93k ohm resister.
    My questions:
    Is that correct, 93k ohms?
    Is it a fusible resistor?
    Lastly, how do I know what wattage?
  • lotas
    • Jan 2016
    • 4668
    • Russia
    This is a megaohm resistor. It doesn't play any role in turning on.
    • BobbyMJ
      • May 2025
      • 12
      Thanks, that makes sense.
      Testing with the AC plugged in I found the following:
      F103
      D102
      D401
      R104
      D402
      J33
      All the above have over 120V
      The capacitor to the left of C501 has voltage, the other large capacitors have little to nothing.
      J38 only has 2 volts as does many things after that.
      Could L401 be the potential culprit?
      What kind of resistor is that?
      • lotas
        • Jan 2016
        • 4668
        • Russia
        L401 is not a resistor (the resistor has the designation Rxxx on the board), but an inductor, choke, coil (they have the designation Lxxx).​
        • BobbyMJ
          • May 2025
          • 12
          Thanks again lotas !
          While following where the power goes on the back of the board, came across this resistor that measures open.
          Assuming that shouldn't be the case?
          Wasn't able to find that exact one through Digi key or Mouser that's in stock.
          Know of an equivalent resistor or an alternative way to go?
          • BobbyMJ
            • May 2025
            • 12
            Can the above resistor be replaced with a metal film resistor with the same specs?
            Like this one: https://www.be-electronics.com/product_p/2wd56.htm
            • lotas
              • Jan 2016
              • 4668
              • Russia
              This is a ceramic, two-watt, current resistor and acts as a fuse, it does not just burn out, look for a short or low circuit in the circuit after it, these can be diodes, PWM microcircuits, MOSFET transistors...
              • BobbyMJ
                • May 2025
                • 12
                Have tested almost everything including removing almost all of the mosfets to test out of circuit and so far, can't find anything else.
                Replaced the circled ceramic cap (image below) which is in the circuit after the resistor, it was blown / cracked open.
                Do you think a blown cap like that can be a symptom or the cause?
                Can a ceramic cap short on it's own?
                • lotas
                  • Jan 2016
                  • 4668
                  • Russia
                  Yes, maybe they often explode, have cracks and short circuit, if you change it, then with a higher voltage of 2-3 kV.
                  When they are shorted, they often take away the MOSFETs (and the PWM, with a built-in MOSFET, like yours) sometimes it passes, and all you have to do is change the ceramic capacitor (resistor, fuse).​
                  • BobbyMJ
                    • May 2025
                    • 12
                    You're spot on.
                    Guess I didn't remove that mosfet above the circled ceramic cap to test.
                    Did that last night and it is indeed shorted!
                    Ordered the mosfet and will try to find a higher rated ceramic cap.
                    Need to order a new ceramic resistor but am unable to find the exact one.
                    Here's the specs ( https://www.koaspeer.com/pdfs/BPR.pdf ):
                    BPR26 -- 2w .56 ohm 5%
                    The BPR26 is proving to be difficult to find.
                    Can I substitute for something like a BPR56 (https://www.mouser.ca/ProductDetail/...9wU3nkyw%3D%3D) ?
                    has a higher wattage though ( 5W) , would it be correct to say bad idea, almost like putting in a large rated fuse?
                    Or substitute with a metal film resistor with the same specs as the BPR26?
                    Thanks again for your help and pointing me in the right directions.
                    • lotas
                      • Jan 2016
                      • 4668
                      • Russia
                      Well, if the MOSFET is shorted, check its wiring (driver, low-resistance resistors, diodes, zener diodes,...), and you can replace the 2 W resistor with a metal film one.
                      • BobbyMJ
                        • May 2025
                        • 12
                        Will do, thank you
                        • electron_jj
                          Panasonic TH-L42D25A checking the PSU output voltage
                          by electron_jj
                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                          08-29-2021, 08:13 AM
                        • maleksa
                          Panasonic TH-L42U5K standby voltage help
                          by maleksa
                          The TV wont turn on and when power is plugged in, the LED will turn from Green to Red and then one Green blink before repeating (Green to Red and one Green blink).
                          Any pointers is much appreciated.
                          I also need help to identify which pin is the standby voltage. I only get the 5V for the 2 pins in the attached picture....
                          03-16-2023, 10:47 PM
                        • x_orange90_x
                          Samsung UN55KU6300F no standby voltage
                          by x_orange90_x
                          I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                          Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                          05-21-2025, 09:59 PM
                        • Bad_IC
                          Philips TV 37pfl5604h/12 no standby voltage
                          by Bad_IC
                          I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                          These are the voltages in some pins of IC fsq510:
                          Vcc=18v
                          D=320v
                          Vstr=154v
                          Unfortunately, I couldn't find the schematic
                          What else could I check?
                          Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                          Thank you​...
                          11-08-2024, 01:07 PM
                        • brock-s
                          Asus GL503GE 3.3 standby voltage low
                          by brock-s
                          An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                          Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                          Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                          07-13-2023, 03:43 PM
