PN64D8000 and Devilish Child
  • mmartell
    • Oct 2013
    • 3189
    Well I don't know if the child is devilish but he apparently threw one of his toys at the screen resulting in the provided image below.
    It looks like the scan ic's are not operating for that portion of the screen yet the image is not black there.
    I was wondering if it was possible to deactivate a scan line or two after restoring functionality to that part of the screen. Seems like a shame to gut it if it can be mostly repaired. Make a nice garage tv
    Re: PN64D8000 and Devilish Child
    It's caused a micro fracture which has fried one of the buffer ICs.
    If you deactivate an IC, you will get a black bar in place of the white bar.
    You will still have the black spot no matter what you do.
    • mmartell
      • Oct 2013
      • 3189
      I mean to replace the ic(s) and deactivate the line(s) that drive the fracture so the rest of the pic returns.
      • Glitcher
        • Mar 2013
        • 673
        • USa
        oh you mean you want to turn off that horizontal line which has the fracture so it won't effect the rest of the IC itself? Interesting idea, not sure if it is possible or not. I know that each pin on the IC will drive one line on the panel, if you can find which pin corresponds with the fracture and remove it? Don't know if it'll work like that or not.
        I guess it'll depend on how big the fracture itself is. Whether its a small pin hole or a bigger crack?
        • mmartell
          • Oct 2013
          • 3189
          Yes, exactly what I'm trying to ascertain.
            Not going to work - as we have found with modern buffers open lines will fry a buffer IC as much as shorts (I am not sure why)
            Still going to have that spot on the screen which will probably only grow...
            • mmartell
              • Oct 2013
              • 3189
              Interesting. I would have though that the line being translucent meant the buffer ic was still active just messed up in another way.
              Btw just so I'm clear the black spot was photoshopped on after to show the location of the strike.
              • mmartell
                • Oct 2013
                • 3189
                According to SM for the hp-t5054 shorted buffer ic lines cause a translucent rendering where n/c cause a line to be drawn black. I know it's a different panel. [CONJECTURE]Maybe the modern failure is that a shorted line shorts all lines together causing translucence ? [/CONJECTURE]
                  How sure are you? Not questioning your logic here, but I've seen exactly that with some panels when cracked - egg like distortion with some dead lines.
                  Pioneer 9G Kuro 50"
                  • mmartell
                    • Oct 2013
                    • 3189
                    On reflection you absolutely could be right about the circle. Have not seen it first hand and sometimes communications are not the best. Thanks for the heads up.
                    • mmartell
                      • Oct 2013
                      • 3189
                      As it turns out tom and after further conversation with the seller you are correct about the black spot.
                      As I am not in need of parts from this unit I will leave it alone.
                      Thanks for your counsel.
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • Chrissygizmo
                        by Chrissygizmo
                        02-10-2025, 12:33 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
                      • ipatch
                        ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                        by ipatch
                        i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                        08-24-2024, 02:36 PM
