Vizio VF551XVT troubles
  • spculater
    • Jul 2014
    • 4
    We Have a Vizio VF551XVT that suddenly quit working while my father, who can open an email and reply but will not send one, was staying at our house. I ran him through a few setup options but got no where.
    Upon arriving home we found that the remote had no effect at all.
    I could turn the tv on with the power button but the only picture was the blue screen.
    I tried all of the HDMI ports and still nothing. (our cable box is connected through the HDMI port)
    I had an digital converter box and hooked it up to the yellow, white, and red ports on the side of the tv (component 2). This gave us a picture and we could change channels but there was no sound.
    I investigated possible solutions online and dismantled the tv.
    I took voltage readings, with the tv on, at all of the identified terminals of the DPS-433BP-3 main board. All voltages were as listed.
    I checked every capacitor on all of the boards an all appeared to be fine, no bulges or defects apparent.
    The only thing that caught my attention was a blinking red LED labeled "D302" on board KLS-550WLTD(2) Rev:1.2.0 . I have not been able to find any information on this.
    I would appreciate any input that helps me solve the problem.
    Thanks,
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Vizio VF551XVT troubles
    Can you post a picture of the mainboard?
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • spculater
      • Jul 2014
      • 4
      Here is a picture of the board.
      • spculater
        • Jul 2014
        • 4
        Has the picture of the board come through?
        Is there anyone there?
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          Received this email from the OP:
          Originally posted by spculater
          The following message was sent to you via the Badcaps Forums Contact Us form by spculater ( mailto:REMOVED ).
          After attempting to generate feedback on a problem with my LED tv I am forced to admit that this site seems to be a total waste of time and effort.
          Gotta love it!!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            Well, some people don't seem to realise that others have a life outside of Badcaps (as strange as it may seem!) Ugh, entitled generation, or just arrogant?
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              wow,well sorry sir it fell through the cracks,a gentle bump would have been a better option...
              Good luck on the repair,I'm out...
              P.S,I asked for a pic of the mainboard,NOT the powersupply.
              • Jesseorrender
                • Sep 2016
                Thanks,
                know this is old but did you ever find out what the red light was I'm trying to figure out same thing with no luck
                • gavric
                  Vizio M70-C3 Half picture is bad, main board on its last leg?
                  by gavric
                  Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                  When tv powers on vizio V logo shows nice on whole screen. picture 1
                  When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                  When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                  When i click video to start playing picture goes black(like when you change...
                  09-02-2021, 08:55 PM
                • ggil44
                  Vizio M65-E0 No Picture, No Sound
                  by ggil44
                  Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                  09-03-2024, 08:30 PM
                • maricm
                  Vizio m65-c1 picture flashing on and off on the screen
                  by maricm
                  HI all,
                  hope someone point to the possible issue before I start buying replacement parts.
                  Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                  Backlight stays on all the time,
                  Sound works fine.
                  screen keeps changing form black to full picture in about 1sec intervals.
                  Picture looks fine with no visible artifacts.
                  I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                  Disconnecting left and right ribbons on...
                  11-25-2023, 06:32 PM
                • Fly_Among_Stars
                  VIZIO E70-E3 Half picture with half TCON
                  by Fly_Among_Stars
                  I have a VIZIO E70-E3.
                  Symptoms: Black screen, no picture, but LED backlights are working.
                  I probed the power board and voltages are as listed on the board.
                  Main board appears fine, too.
                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                  There are two separate ribbon cables feeding the LCD.
                  If both are connected, the screen is black.
                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                  04-24-2023, 08:20 PM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
