Samsung TV UN75NU7100/Power Board BN44-00874C
  • EazyBone
    • Jun 2023
    • 1360
    • United states
    #41
    I can't get the old spare board to stop popping. Not sure what's wrong. But I have compared the cold side leds parts, and something is off on the board that's flashing. No idea what. The mosfets on the flashing one read 3megaohms and climbs to 50m ohms
    The mosfets on the, probably good but popping board reads 4.6mohms steady (led cold side)
    • valvashon
      • Oct 2020
      • 99
      On my Samsung board I had a bad dual diode unit that was between the similarly numbered MOSFET's- you might check that if it exists on your board. The first couple of numbers of our PS boards are the same but they are quite different boards.
      https://www.badcaps.net/forum/troubl...rd-blows-fuses
      • Larrob19
        • Mar 2025
        • 30
        Well that sounds like some good news. Good luck in your search. I'll be watching closely .
        • EazyBone
          • Jun 2023
          • 1360
          • United states
          #44
          So I figured out the old bad board. Original what blew was the other mosfets up top in the picture. The main caps were shorted because those mosfets were shorted. Replaced and tv fires right up. Now that I have a working good board, maybe we can help the OP and me figure out the old board with the blinking leds. I'd assume it's probably a similar issue?
          What can I do with good board to help test the led areas for us both?
          Edit. I call everything that looks like that a mosfet lol don't know if that's true.
          • EazyBone
            • Jun 2023
            • 1360
            • United states
            #45
            So the only discrepancy I have found so far is.
            When I check the voltage on pins 10 and 11 on the bad board I get 1.8 volts. When I check it on the good board against 0.005 volts or nothing.
            So far the other voltages to the LEDs seem correct except for these two pins. I'm kind of just probing around maybe you can check what you get on 10 and 11 using the chassis ground and check the voltage on that jp949 hole the probe is in in the picture. Seems these are connected
            I'm doing the tests with the PSU out of the TV as a standalone.
            Also I am tracing the line, can't figure out where it goes. Any help?
            • EazyBone
              • Jun 2023
              • 1360
              • United states
              #46
              So when plugged into the tv, those same spots read 190v ground chassis on good board. And fluctuates voltages when plugged in on bad board. No idea what that means. I'm not able to help ya any further if no one else can point me in a direction. I can't learn if I don't know what to look up or how to find it and I've searched pretty through for a solution. Sorry
              But at least we have same problem and it seems like it's the power board for you.
              When I keep all ribbons connected to the Tv and only disconnect the PSU from the LEDs (with the bad board) I still was able to get a startup sound, which sounds like you are not getting. So who really knows.
              Tried to help.
              • nomoresonys
                • 12306
                • U.S.
                #47
                With fluctuating voltages you might want to check over capacitors and voltage regulating diodes.
                • Larrob19
                  • Mar 2025
                  • 30
                  I checked my board and I get 281v at pin 5 and 10 and nothing at the other pins and nothing at jp949. The other pins are millivolts.
                  • Diah
                    • Feb 2013
                    • 6496
                    rework yours MOSFET , not any part new are new..
                    • EazyBone
                      • Jun 2023
                      • 1360
                      • United states
                      #50
                      Is that connected to lights or on bench
                      • Larrob19
                        • Mar 2025
                        • 30
                        Bench
                        • Larrob19
                          • Mar 2025
                          • 30
                          Is this of any help.
                          • nomoresonys
                            • 12306
                            • U.S.
                            #53
                            Wonder if it might be a bad led driver IC on the powerboard. Suppose if one of you has a working model on the bench you can test the pins of the working tv led driver IC against the non-working tv. May need the datasheet.
                            • EazyBone
                              • Jun 2023
                              • 1360
                              • United states
                              #54
                              Yea, I do have working one. I don't know where the IC is, definitely something I can test if pointed in the direction
                              • nomoresonys
                                • 12306
                                • U.S.
                                #55
                                I can't see a clear sharp image of none of these boards, maybe check out Bobby here he knows what hes doing: https://www.youtube.com/watch?v=xjVt14h_af4
                                • Larrob19
                                  • Mar 2025
                                  • 30
                                  I viewed the video but nothing seems to help in my situation.
                                  • nomoresonys
                                    • 12306
                                    • U.S.
                                    #57
                                    As per the video, IF you plug in the powerboard by itself, NOTHING else hooked up and you don't have around 400 volts on the big filter caps, you have a pfc/power factor correction issue. You need to at least fix that issue. Honestly in your situation, I think a replacement board is your best bet.
                                    • nomoresonys
                                      • 12306
                                      • U.S.
                                      #58
                                      It's a good sized tv, if you are happy with the picture and everything it could be worth a replacement board. It is a samsung and they have fallen off in reliability but who knows, if you don't push the backlights too hard you may get some more use from it. Myself I wouldn't buy a new samsung or invest much in repairing one, just WAY too many panel faults in last decade or so.
                                      • Larrob19
                                        • Mar 2025
                                        • 30
                                        Yes I think your right about the PFC. I plugged it in to check the voltage on the 3 big caps and it's showing about 60v. Also after checking the two Mosfets that I changed originally 1 was burnt again. I think it's time to dig a hole and bury it in the back yard.
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                          09-07-2024, 05:50 AM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • valvashon
                                          Samsung UN65KU6290F PS board blows fuses
                                          by valvashon
                                          Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                                          Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                                          11-27-2023, 01:09 PM
