Toshiba 26AV505D TV Blue Screen
  • jonnybgood
    • Jul 2014
    • Malta
    I am trying to fix this TV which wasn't turning on. I changed the mainboard, and checked the power supply voltage points and all seemed to be well.
    The problem is that when I switch it on, the screen would just light up in Blue and there is nothing else; no words no sound. (Backlight seems to work fine).
    What should be my next step? I have a scope which I can use to monitor any signals.
    thanks
    Brandon
    Re: Toshiba 26AV505D TV Blue Screen
    I would try checking the LVDS in to the panel. I have encountered a bad LCD panel on this model before.
    • jonnybgood
      • Jul 2014
      • Malta
      Thanks for your help, I checked the LVDS and all was OK, I then found out that one of the ribbons from the panel PCB to the actual TFT was faulty.
        Does not surprise me I came to the same conclusion. This TV is not made by Toshiba but instead by a Chinese ODM.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
          09-06-2024, 05:27 AM
        • sigmeyer
          Toshiba 50UL4B63DG faulty screen?
          by sigmeyer
          I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
          08-30-2025, 08:13 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
          09-06-2024, 05:59 AM
