Vizio E420VA mainboard replacement
  • freakaftr8
    • Oct 2012
    • 3743
    Hey all,
    well here is the situation, got a Vizio 42" EV420VA from a friend that had a power surge destroy the mainboard. Couldny locate one but did find one on ebay for a 46" model.
    Basically set powers up now but the screen is stretched and green, lacking color.
    How do you preset option bytes in the service menu? and furthermore how do you access the service menu on Vizio?
    I had all this info saved on my phone but recently smashed it on accident.
    • 30951
    Re: Vizio E420VA mainboard replacement
    a wise member once posted:
    Vizio Service Menu Method 1
    1. Turn The TV off.
    2. Press and hold the {CH +} & {CH -} buttons on the TV.
    3. Then press and release the {POWER} button on the TV.
    4. Release the {CH +} & {CH -} buttons.
    5. Now press the {MENU} button on the remote.
    6. You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
    7. Press and hold the {MENU} button for few seconds.
    8. The Service Menu will be displayed.
    Vizio Service Menu Method 2
    1. Turn The TV off.
    3. Then press and hold the {POWER} button on the TV.
    4. Keep all three buttons pressed for few seconds.
    Vizio Service Menu Method 3
    1. Press and hold the {EXIT} button on the remote for 3 seconds then release it.
    2. Then press the {1} {2} {3} buttons on the remote.
    3. To exit, press the {EXIT} button.
    dont blame me if it's wrong, i just did a "cut n paste"
    • freakaftr8
      • Oct 2012
      • 3743
      awesome thanks! Ill give it a try in a few minutes
      • freakaftr8
        • Oct 2012
        • 3743
        None of these options work.
          • 30951
          who actually makes it inside?
          • freakaftr8
            • Oct 2012
            • 3743
            Have no idea. No names anywhere
              • 30951
              maybe try these?
              GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
              VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
              VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
              Push "Menu" on remote and then push "Vol-" and "Input" on keypad
              GV46 / P50HDM / P50HDTV10A
              Press "Ch-" and "Ch+" buttons together once on keypad
              GV42 / L42 / VP42HDTV10A / VP50 / VX37
              Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
              P42
              Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
              VM60P
              Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
              The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
              GV47
              Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
              SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
              VO320EP8 / VO370M / VO420E / VP504 / VP505
              Press "Menu," and then press "2," "4," "8," "9."
              VA19 / VA22LF / VA220E / VA26
              Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
              VA320E / VA320M / VA370M / VT420M / VT470M
              Press "Menu" and then press the following combination: "1," "9," "9," "1"
              VW22 / VS370E
              Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
              • freakaftr8
                • Oct 2012
                • 3743
                None of those work either. This things stubborn
                  • 30951
                  vestel?
                  Menu 4725
                  aaannd
                  Chinese generic boards and most respond to the following for factory mode:
                  Hold down volume minus (Volume down) on set and press 'recall' on remote.
                  'Recall' is the button that activates the channel number and clock onscreen.
                  After you have made your changes, in most cases, pressing 'power' on the remote will clear the factory mode.
                  On some models pressing the 'AV' button will revert things to normal operation.
                  In rare cases, the sequence first described above - (Vol - on set and recall on remote) will have to be repeated at least once more.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    None of these are working. And I cannot find any info online
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      However I noticed that the mainboard has a USB. It has a media player for pics and stuff but can't locate a firmware from Vizio or the internet. Wish I could just transfer the EEPROM ic from old board to new. But not sure which ic holds the firmware
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Doesn't the8 pin EEPROM retain the firmware?
                        • aaronwt6
                          • Apr 2013
                          • 855
                          • US
                          Post a picture of the board please. I'm not sure if the eeprom swap is going to fix it though. I've had mixed results swapping these boards in Vizio's. They use so many different panels it's hard to keep up.
                          • aaronwt6
                            • Apr 2013
                            • 855
                            • US
                            If this is the board you have, I've circled the Eeprom
                            • tibimakai
                              • Jan 2012
                              • 3680
                              http://www.shopjimmy.com/vizio-e420v...eprom-only.htm
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Yep that's the board. Too bad I can't get into the service menu and poke around in the options kind of like Samsung and thier panel options although I doubt it will do any good.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Well ordered the EEPROM. Let's hope for the best.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Well I thought I'd try the eeprom from my old e420va mainboard. It presented no control. Couldn't turn it on. Power supply was sending voltages. Got the new eeprom in from shop jimmy and still dead. Checked all fuses. Good. Any ideas?
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      I'm still stumped on this one. I'll run down the symptoms again.
                                      got this from somebody that said they had a power problem in Their house. I replaced the main board with 1 for a 47 inch vizio and even though it now powered up the screen was all distorted and sTreched. obviously the 47 inch panel in the 42 inch panel are not compatible. So I soldered The EEPROM in from the original 42 inch version mainboard and then all the sudden I have a no power situation no standby light and the TV would not power on so I figured it was a bad EEPROM. So I ordered a new one. Still have the same issue. Getting power from the supply and all fuses on mainboard are ok. Any ideas?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        All the voltages at the PS are good?
                                        • AustinComputerDoctor
                                          Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
                                          by AustinComputerDoctor
                                          I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
                                          I see backlite is active,
                                          but I cannot get the screen to return back to menus , etc
                                          This is all after replacing the mainboard...
                                          any assistance is greatly appreciated.
                                          03-25-2024, 12:43 PM
                                        • Mirenia
                                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                          by Mirenia
                                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                          03-30-2025, 06:47 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Devonavar
                                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                                          by Devonavar
                                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                          So, I've ruled out the PSU for now.
                                          The reboot loop...
                                          08-14-2022, 08:46 PM
                                        • maricm
                                          Vizio P65 with P55 mainboard
                                          by maricm
                                          IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
                                          Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
                                          And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
                                          04-23-2024, 08:25 AM
