Trying to Save - Samsung 60" UN60D6000SFXZA - Displays flashes on then... nothing
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Picked this one up the other day.
Name:	Screenshot 2025-04-15 at 5.19.30 PM.png
    Previous owner says it would just go off by itself.
    When I plugged it up I get a solid standby light.
    WHen I power it on i see a HALF the screen (right side) light up then nothing.
    Its dim... but not completely off. The TV doesnt respond to any commands other than pressing OFF on the remote.
    I was pretty puzzled until i realized this is not a plasma tv but rather a LED-LCD TV with backlights.
    It looks and feels JUST like a plasma.
    Quick search on this thread shows that the backlights are the main issue with these.
    I'll tear into it tonight or tomorrow to see if I can use my backlight tester on it to confirm.
  • EazyBone
    • Jun 2023
    • 1328
    • United states
    13 yrs old. Good run. I can't even waste my time with those. Samsung used screws back then takes so long to disassemble
    • nomoresonys
      • 12187
      • U.S.
      These older models are more reliable, samsung went completely to shit a bit later all the way up til now.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8153
        So true!
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8153
          Well they had their own problems, I would say…
          • nomoresonys
            • 12187
            • U.S.
            Indeed, I think the bean counters at samsung have been paying attention only to making them as cheaply as possible, quality be damned. slap together ship it out. Sure fire way to turn a good reputation bad, which is what they have done. I've had and seen the most problems from samsung tvs from prolly 2015 and newer.
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              Mission FAILED.
              The backlights i ordered arrived today. I went to install them but the panel display was stuck HARD to mounting strips. Sort of like glue...probably bcos of the age. I went around it carefully with my heatgun, plastic pry tool and suction cups heating, lift and securing the panel. I did the right side and all the bottom where the delicate panel boards were dangling by their delicate bonded film. Got past that area and started to heatup the left side. As i was moving my heat gun away the cord caught on one of the film strips! And took half of it off the panel.
              Click image for larger version  Name:	20250425_162711.jpg Views:	0 Size:	2.15 MB ID:	3623366
              Normally i would have had these taped to the panel but bcos i was using the heatgun on the area it was not possible. In hindsight i ahould have immediately taped them to the panel once i had cleared that side but i was focusedand wanted to keep going.
              UNLUCKY!
              • Unspun01
                • Jun 2011
                • 343
                @KYBOSH: Well, for your next trick, you can buy a replacement COF (chip on flex) cable and learn about re-attaching such a cable to the panel using anisotropic conductive film/tape, and conventional resoldering to the panel buffer strip (if needed).
                If that COF flex cable is not damaged, you might only need to re-attach to panel using that anisotropic tape.
                I once repaired a TV for a customer who yanked on their COF flex cable during "cleaning". But in their case, the flex cable was still attached to the LCD panel itself, and the damage was to the flex ribbon cable where it attaches to the panel buffer board (the green PCB). I gently heated and removed the flex from the green PCB, cleaned up the solder interface, pre-tinned the individual pins on the green PCB, tinned the traces on the flex cable, lined them back up under a big magnifying lens, and by using lots of flux and a wide flat solder tip and not too high of a temperature (300C), I heated the solder through the flex cable and re-made each individual solder connection. TV was saved. Luckily I didn't have to replace the flex cable.
                It would have been easier with ACF tape, but I did not have any, nor was I aware of its existence at the time of the repair.
                Here is an into video to ACF tape bonding: https://www.youtube.com/watch?v=biHFJFHpqdM
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
