Lightning surge Panasonic TV help
  • dungbeetle
    • May 2007
    • 94
    We had a storm last night and the tv was on. The power went out momentarily 2 or 3 times. No big deal. Today it seems the cable channels in the 50 range are more fuzzy than the others. Our other tv is perfectly clear. Is it possible that its an easy component fix or more likely a board replacement for the channels? I never knew that just some of the channels could be affected but that seems to be the case. Its a cable ready tv.
    Regards,
    db
  • dungbeetle
    • May 2007
    • 94
    Re: Lightning surge Panasonic TV help
    Thanks to all the help I got here the tv is working again...Seems the lightning messed up a filter from the cable company as the neighbor had them over yesterday. The guy climbed the pole and messed with it and now all is normal. The funny thing is that the other tv seemed unaffected by the problem so it must be a better tv. Weird.
    Thanks again,
    db
    Regards,
    db
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • SluggerB
      Panasonic TH-50PX80 killed by lightning strike, help me save her!
      by SluggerB
      Yes it's a 17 year old Panasonic plasma!
      I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
      06-04-2025, 07:02 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • r2digital
      Harmon Kardon AVR340 no sound on 4 channels
      by r2digital
      Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
      03-09-2024, 01:33 PM
