JMB JT0246001/01 Stand by issue
Re: JMB JT0246001/01 Stand by issue
UPDATE
got another board, and tv is all working fine, but the remote will no longer control the tv,
can i swap the parts from one board to another so that the remote will then control the tv ?
if so, can someone point out the part to swap from the pics at the start of this thread
thanksComment
What TV did the replacement board come from? It might be better just to find a remote for the other TV.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
baird 40 inch samsung screen,
also turns out that the buttons are all about face as well, on/off = sorce, lolLast edited by finntricky; 08-02-2014, 11:44 AM.Comment
Think you'll have to get another main board then, not sure if there is much you can do.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
buttons not a problem, just got to pull the wires from plug and swap them about, so they match up,Comment
by Titus6Hello everyone,
I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...1 Photo -
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
Assuming...7 Photos -
by fuxxyThis is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
Plug the set in, and it will turn on and functions with no issues.
After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes... -
by brithepi2kHi,
I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
cheers...5 Photos - Loading...
