PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
  • bohaboha
    • Nov 2012
    • 998
    • sweden
    when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
    Do I disconnect the plug from the power supply, no backlight
    Thought the backlight would light up when you remove the plug from the power supply but no
    What could be wrong if both halves work separately?​
  • bohaboha
    • Nov 2012
    • 998
    • sweden
    Good day folks. any suggestions ?
    • lotas
      • Jan 2016
      • 4611
      • Russia
      Well, from the photo you can see that the problem is on the left side, on the right it is clearly visible (black color, so black).
      • bohaboha
        • Nov 2012
        • 998
        • sweden
        Thanks for the reply Lotas I think the pictures I have presented are mistaken taken from a bad point of view I put better pictures for a better assessment.
        and as you see TV works as it should but on each half separately
        now I wonder where to start looking to figure out the error maybe T-CON board ?​
        • Diah
          • Feb 2013
          • 6376
          try first to downgrade the firmware with upgrade_loader ... download this and unzip copy upgrade_loader file on root USB formatted FAT32 in MBR Mode., when you get on screen upgrade in progress good sign. when nothings leave the TV do downgrade until the Tv reboot...... at this case you have issue at Panel buffer boards or one gate Transistor inside the screen.
          • William1967
            • Nov 2017
            • 206
            • Netherlands
            This has nothing to do with software/firmware. This is a panel problem, try to block some datalines with some tape and the problem will be solved. The 58" with a Panda panel is known for this problem.
            • bohaboha
              • Nov 2012
              • 998
              • sweden
              Thanks Diah is there any special procedure to follow to carry out this firmware downgrade after downloading it? I mean should the TV be on or should you use or not the Remote Control
              • bohaboha
                • Nov 2012
                • 998
                • sweden
                Thanks William1967 your suggestion is pretty easy to make while waiting for Diah's answer but need to know which side to start with and can i do it directly on the Tcon side or on the panel buffer side and most importantly how much datalines should be covert?
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Did you swap LVDS cables to see if you have the same problem?
                  If NO then the LVDS cable needs to be replaced.
                  If YES then replace or repair the T-CON Bd.
                  • bohaboha
                    • Nov 2012
                    • 998
                    • sweden
                    Hi I haven't done anything yet trying to gather all the info to start investigating this tv but its easy to fix what you suggest then I'll investigate Tcon a little closer thanks
                    • Diah
                      • Feb 2013
                      • 6376
                      you have complete image on half screen when you disconnect left and right ribbon cable. this why i suggest to downgrade firmware.
                      on yours windows PC run CMD as administrator
                      type:
                      diskpart
                      list disk ( usually yours USB will show disk 1 if you have only one HDD on yours PC)
                      select disk 1 ( if yours USB look as list disk 1 )
                      clean
                      convert mbr
                      create partition primary
                      active
                      list partition
                      select partition 1
                      format fs=fat32 quick
                      assign
                      exit
                      exit
                      copy upgrade_loader on the usb root , plug it in usb on the side ... plug the TV in wall.
                      • bohaboha
                        • Nov 2012
                        • 998
                        • sweden
                        type:
                        diskpart
                        clean
                        convert mbr
                        active
                        list partition
                        select partition 1
                        assign
                        exit
                        exit
                        thank you very much Diah
                        • bohaboha
                          • Nov 2012
                          • 998
                          • sweden
                          type:
                          diskpart
                          clean
                          convert mbr
                          active
                          list partition
                          select partition 1
                          assign
                          exit
                          exit
                          Hi everyone who contributed to this thread I think the error is corrected with William1967 suggestion and with the first attempt kapton tape on the first four dataline on the left ribbon on the Tcon board seen from back thanks everyone
                            • 12201
                            • U.S.
                            Well I think this was unusual, what I have seen mostly where taping worked was a flaw on one side, NOT a good picture on each but there it is.
                              • 12201
                              • U.S.
                              Have you seen this often William 1967, with a good display on both sides?
                              • bohaboha
                                • Nov 2012
                                • 998
                                • sweden
                                I was also wondering if it was usual even it is a first time for me but as William1967 says it seems to be usual for the 58 hope he will se this
                                • William1967
                                  • Nov 2017
                                  • 206
                                  • Netherlands
                                  I have seen that very often.
                                  Sometimes repairable with a little piece of tape but what sometimes appeared was a spot with less red than normal or thin lines running through the image from left to right.
                                  Sometimes clearly visible but sometimes not.
                                  The Panda panels are bad and come in many brands but especially the 58 inch is very bad.
                                    • 12201
                                    • U.S.
                                    Thanks William.
                                    • bohaboha
                                      • Nov 2012
                                      • 998
                                      • sweden
                                      for me absolutely as new no problem at all so long hope it will last
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Audeze
                                        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                        by Audeze
                                        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                        Does...
                                        10-06-2024, 08:54 PM
                                      • HTR-Informatique
                                        by HTR-Informatique
                                        02-09-2025, 06:51 AM
                                      • totof
                                        LG 43UF640V backlight good but black screen and no sound
                                        by totof
                                        Good morning.
                                        I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                        I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                        In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                        HVDD : 7,28...
                                        04-13-2024, 11:37 PM
                                      • turmix
                                        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                        by turmix
                                        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                        During another reassembly, I made a mistake, and...
                                        01-29-2024, 03:48 AM
