MMC6100B 25 Sub needed
  • mu2
    • Oct 2009
    • 217
    I'm working on a Samsung LNS3241DX/XAA that has vertical lines at times.
    Already checked the power supply capacitors.
    I was able to find that the regulator on the T-con (MMC6100B-25) has a good 3.3 volt input but the output is 1.7 volts.
    I cannot find the spec sheet on the net.
    Is there a 2.5 regulator substitute that has the same case style and pin outs?
    Something stocked by Digikey would be great.
    Thanks in advance,
    Mike
    Re: MMC6100B 25 Sub needed
    3.3Vin for 2.5V REG is pretty low, only 0.8V drop out voltage, most I have seen is about 1.2V drop out range. 0.8V does not sound right, I cannot locate data sheet for this regulator either.
      I have seen LDOs with a 0.1V dropout voltage. An LD1117 will usually manage 0.8V at low load current.
        Wow, 0.1V, how the heck do you get the headroom for regulation.
          I have used this before.
          500mA with about 200mV dropout.
          Not used this myself, but am considering it for maximum battery life on a widget running off two coin cells (the problem is two coin cells would slightly exceed the maximum VIN) - 50mV dropout:
          http://www.ti.com/product/tps72215
          Linear has a 1.5A LDO with a 100mV dropout, although the price is high, because Linear do that...
          • mu2
            • Oct 2009
            • 217
            Thanks for the responses.
            I think I found something.
            Digikey has them as 576-3601-5-nd
            Can anyone verify this as a good sub?
            Mike
            • mu2
              • Oct 2009
              • 217
              Forgot to mention that it looks like that the original part is rated at 1.3 amps.
              The Micrel part is listed at 1.5 amps.
              Mike
              • mu2
                • Oct 2009
                • 217
                Just wanted to update the previous post.
                I replaced the 2.5 volt regulator on the t-com board with Digikey 576-3601-5-nd.
                The output had been 1.7 volts and the set has been on for over an hour with a good picture.
                I also replaced the Capxon power supply capacitors for good measure.
                The symptom was fine vertical lines that sometimes filled the screen or at times only in the upper 1/4 of picture. Usually the picture started out ok but worsened but it would also be poor when initially turned on.
                Mike
                  Mike
                  So the output is now 2.5V or 1.7V?
                  • mu2
                    • Oct 2009
                    • 217
                    The output is now 2.5 volts.
                    The bad regulator (2.5 volt) that I replaced had an output of 1.7 volts.
                    Set has been on for 8 hours now without an issues.
                    Mike
                    • tw2005
                      • Oct 2011
                      • 6458
                      Found this forum post,
                      http://www.plcforum.it/f/topic/14851...5-equivalente/
                      LD1117S25TR also used and worked as a replacement, output current rated 0.8A
