Samsung LE40A656 vertical line bleed, ideas about fix (panel ageing?)
    About 3 years ago I fixed an LE40A656 for my parents with the common bad capacitors issue.
    Now the TV exhibits another fault, which is rather odd. Essentially any bright part of the image will bleed vertically across the panel although it's more predominant near the top of the panel. Turning the contrast down below about 85 hides the lines except on the menus, which seems to have a fixed brightness.
    I have a theory that the panel itself might be aging, rather than this being a tab bonding issue. The bulbs emit UV light which might be damaging the pixel TFTs requiring a stronger or weaker drive voltage. Or it could be related to heat over time - perhaps temperature related.
    I am going to investigate changing the VGL voltage (this turns pixels off, I suspect it may be too marginal), if this is not possible I will try reducing AVDD.
    • 31191
    Re: Samsung LE40A656 vertical line bleed, ideas about fix (panel ageing?)
    i'v seen ghosting / trailing too.
    i would check the panel for bad or missing bias voltages.
      Thing is the picture is OK mostly - only bright lines cause the bleeding. If you set the contrast low they never occur. Apparently the issue occurred slowly and got worse over time, which is interesting.
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Pictures of fault,boards front/back,ID off all boards etc.. Do you have a DMM? Any knowledge of electrical/wood/metal? Cooking?.... lmao.........
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
          • 31191
          lol
            Long delay in posting.
            Going to have a look at this thing soon.
            Found that increasing AVDD (by loading feedback point) made fault worse.
            Going to try decreasing it.
            • cliff_hootarski
              • Jul 2006
              • 411
              Too funny, Martino!
              • debugger
                • May 2014
                • 47
                • usa
                I have a LG LN40A630M with the same symptoms. It gets a decent picture with the contrast turned down. Do these pictures look like your fault.
                  Yep, that's the same as what I'm seeing. Haven't had a chance to hook it up to a source properly yet.
                  • Flipk614
                    • Oct 2014
                    • 12
                    • United states
                    • Flipk614
                      • Oct 2014
                      • 12
                      • United states
                      Okay here are some pictures of mine.
                      1-Tv right at startup
                      2-After about a minute in PC mode
                      3-Close up of lines in PC mode after 1 minute
                      4-Xbox guide Hdmi after 3-5 minutes
                      5-Cable after 3-5 minutes
                      6-Back of tv
                      7-Tcon board LJ94-02853
                      • debugger
                        • May 2014
                        • 47
                        • usa
                        Tom, Badcaps veteran truep told me he fixed a sony with similar problem, with a main bd.
                          Different fault, I think. These are panel faults.
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            Hey,--Tom.....
                            You know what you need to do.....
                            Take the set to a TV Repair shop! Haha!
                            Have you tried a T-Con out of curiosity.....?
                            TELEFIX
                              Not going to bother with a t-con. I know it's panel related but maybe I can get some life out of it.
                              • debugger
                                • May 2014
                                • 47
                                • usa
                                A t-con did not fix my set.
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Service menu, run the test patterns and see if this happens there.
                                    Can't do that on A656. But it is panel failure, no way for it to be anything else. After a few TVs, you can tell when a Samsung panel has died!
                                    • Flipk614
                                      • Oct 2014
                                      • 12
                                      • United states
                                      Tcon didn't help mine. Helped a little. I'm gonna tear it down again and check out the tabs this weekend with the help of component cooler and hair dryer. Any way you can rule out the bad panel. Still got my hopes up on this one. Hate to see it go.
                                      • cubytus
                                        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                        by cubytus
                                        Hi to all,
                                        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                        01-10-2024, 01:26 AM
                                      • otaku_nut
                                        Vizio E701i-A3 fixed but now has red vertical line
                                        by otaku_nut
                                        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                                        08-19-2025, 06:11 PM
                                      • TrueSword88
                                        Kogan - KALED65XU9220STB - Blue Vertical Line
                                        by TrueSword88
                                        Hi all.
                                        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                        The line just happens to coincide with the end of COF and start of the next COF (attached).
                                        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                        Hoping to fix...
                                        05-05-2023, 04:28 PM
                                      • FALKLAN
                                        Running Line Voltage and Integrating LED Pods - Automotive
                                        by FALKLAN
                                        Howdy everyone! I hope all is well where ever you are!
                                        I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                        I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                        02-05-2025, 12:30 AM
                                      • mindoverflow
                                        ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                                        by mindoverflow
                                        hello,
                                        there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                                        I changed pads and thermal paste.
                                        I run mats test but it is reporting 0 errors.
                                        I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                                        After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                                        02-09-2022, 03:22 PM
