Where would I buy replacement LED Strips?
    My edge lit TV LED had a strand burn out, I dismantled the entire tv and removed the offending LED Bar, but how would I replace it?
    Re: Where would I buy replacement LED Strips?
    Did you try ebay or shopjimmy ?
      The make and model of your TV will help others answer your question
        The parts I am looking for come from a Sony KDL-40NX711
        I need 1 strand of LEDs. Shopjimmy and ebay were not useful in my search.
        3 codes are printed on the bar of 63 LEDs
        SLS40_5630_120_1D_B_Rev1
        KM-8 94V-0 1028
        On the back a barcode with
        K928 H
        100012
        40U168
        The Bracket the LEDs is attached to is labeled
        D001005A0 40-UP LJ64-02635A
          pictures?
            is this it?
            http://www.ebay.com/itm/LJ64-02267A-...item338f98da0f
            or this one?
            http://www.ebay.com/itm/Sony-LED-Str...56076834&rt=nc
            http://www.ebay.com/itm/Philips-40PF...52491279&rt=nc
            hopefully this helps
            I have learned from many on here that different brand tv models use the same parts from the same manufacturer
            but not always can be interchanged
            So be careful and ask if the parts are compatible and returnable
              Thanks so much guys. Unfortunately I don't think any of your ideas will work, as the LED is 63 Bulbs long and is connected via flat ribbon. The options you shared are 56 bulbs and are "wire" connected.
              Here are 2 photos:
                another option is for you to call a tv repair shop and ask them to order it for you.
                but you are going to pay a very high price for it
                  User BammBammFran found the part I needed! http://www.iccfl.com/product_info.php?products_id=21543
                  And only about $30 out of pocket!
                  Hopefully they work.
                    nice
                      You could replace the bad LED.
