Panasonic 37PX8EA 1 Blink error
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey People ,
    Im new to this forum so first of all hi!
    English is not my first language so forgive me for some grammar mistakes.
    I got a Panasonic 37PX8EA which has the 1 blink error message , been reading a lot of information on the internet/this forum and if im correct the problem is the "STV 5v Sense DG board" right? Where on the DG Board can i find the component that is causing the problem?
    I also read that it can be a EEPROM problem? Where is the EEPROM located on the DG board?
    I already tested the tv with a spare power supply but it does exactly the same with both power supply's. So it turns on , i hear the relay click and after a few seconds it clicks again and the led goes from green to red.
    Its easy to throw away the DG board and buy a second hand board from ebay but i want to learn more about these boards.
    More information about this plasma to give you guys as much information as i can! ( im pretty new to this )
    1) The TV has a total of 4 boards. ( Power supply , Zsus , Ysus , DG board. )
    2) DG board model nr = TNPH0711 / TXN/A1BVUD
    I have a different panasonic tv as a spare but it has a different DG board. ( 1 big board with a small board behind it ). ( model TNPA4310 )
    If anyone could help me out or point me in the right direction would be greatly appreciated. thx!!
    Mark
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic 37PX8EA 1 Blink error
    I hope that i named the boards correctly. With DG board i mean the board that has all those IC's. ( IC9001 for example ).
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Anyone?
      • selldoor
        Slow Learner
        • 7870
        A picture of the board you are asking about might create a bit more interest.
        Post it using manage attachments should be no bigger than 2mb and 2000x2000
        • charles frost
          FROSTY
          • Mar 2014
          • 18
          Try unplugging Y and z sus. boards then turn on set. This could eliminate 1/2 your problem,
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Thanks for the replies guys!
            Here are some pictures of the boards.
            http://s12.postimg.org/4x6f3lfbh/20140624_211816.jpg
            http://s29.postimg.org/x1gotq9qv/20140624_211828.jpg
            http://s29.postimg.org/qp1jjw6on/20140624_211839.jpg
            I already tried to remove Y/Z sus boards but the problem stays the same! The blinks never change to 5/6/7/8/9/10 etc.
            • selldoor
              Slow Learner
              • 7870
              I did ask you to post the picture on site so they remain for reference.
              They are not clear enough to see the detail - you will need to google the part numbers and check out which are eeprom.
              I believe ESMT make bios chips so may well be those.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Ok im sorry i didnt know how.... :/
                Ok thx , i will try to find out wich 1 is the EEPROM. Do you think that chip is the problem?
                When i remove just the Y-sus board the system turns on and gives 1 blink code
                When i remove 1 cable from the Z-sus board the system turns on and gives 1 blink code
                When i remove the Z-sus completely the system does NOT turn on.
                When i remove just the mainboard the system does not turn on.
                The blinks never change in all combinations.
                • selldoor
                  Slow Learner
                  • 7870
                  eeprom chips are also made by Atmel if you can find any of those?
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                    by sam_sam_sam
                    After all of...
                    07-13-2024, 08:14 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
                  • tiku
                    Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
                    by tiku
                    Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
                    I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
                    09-05-2021, 05:02 AM
