Samsung ue49mu6120 No Standby
This topic has been answered.
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Have a Samsung ue49mu6120 with no standby light,
    unplugging mainboard cable from the power supply turns backlight on.
    power supply BN44-00807F
    Main board BN41-02568B​
    Some other users suggest that the 25Q40 EEPROM might have become corrupted,
    Could someone more knowledgeable take a look and see if mine is corrupted?
    Thanks in advance:
  • Answer selected by Gjackson at 02-12-2025, 04:15 PM.
    nomoresonys
    • 12181
    • U.S.
    Intermittent faults are tough ones if it was intermittent, could be what you soldered did it or maybe there was a bad connection that got better just by unhooking and re-hooking cables, guess just test it for a few hours and see.
    • lotas
      • Jan 2016
      • 4595
      • Russia
      Your dump is working.
      • Gjackson
        • Aug 2021
        • 134
        • Malta
        Thanks Lotas,
        any clues how I should move forward and what to check next?
        For testing I have the mainboard and power supply on my bench connected to each other, it seems like 13v is being generated and the mainboard warms up slowly and then after a while it switches into standby mode 8v and I can't find anything wrong with either of them, 3.3v and 1.8v are generated. Right now I don't have the tv chassis to test with, but maybe the wifi module or t-con board is shorted and was shorting the power supply?
          • 12181
          • U.S.
          Check voltages on CNM803, neg. probe on chassis ground, pos. probe on each pin, read tv in standby=plugged in but power off, take note, leaving probes where they are hit power button, take note of any change, can skip the grounds, report results.
          • Gjackson
            • Aug 2021
            • 134
            • Malta
            Thanks for the reply, with the two boards set up on the bench here are the readings:
            while on standby:
            A13V = 8.9v
            FAIL_COUNT = 0v
            POWER_ON = 0.09v
            PWM_BLU = 0v
            OD_ON/OFF = 0v
            ANA_DIM = 0v
            while powered on:
            A13V = 12.8v
            FAIL_COUNT = 3.3v
            POWER_ON = 3.3v
            PWM_BLU = 0.04v
            OD_ON/OFF = 3.3v
            ANA_DIM = 0.08v
            I'm assuming pin 1 here spells out FAIL_COUNT because I can't really read it
            • Gjackson
              • Aug 2021
              • 134
              • Malta
              Interesting to note, if I unplug the mainboard from the power supply and take readings again it seems to fluctuate, I don't know if this is intended behavior from the power supply:
              A13V = Fluctuating
              FAIL_COUNT = 0v
              POWER_ON = Fluctuating
              PWM_BLU = Fluctuating
              OD_ON/OFF = Fluctuating
              ANA_DIM = 3.3v
              Here's the waveform for A13V when fluctuating:
              And for POWER_ON , PWM_BLU, OD_ON/OFF they all virtually look the same as this:
              A faint click can be audibly heard with every rise of the waveform coming from somewhere on the PSU​
              • lotas
                • Jan 2016
                • 4595
                • Russia
                Fluctuations in power supply occur because there is no load at the output...Load it (13v) with a car incandescent lamp.
                • Gjackson
                  • Aug 2021
                  • 134
                  • Malta
                  The lamp lights up fine if the mainboard is also connected:
                  Click image for larger version  Name:	20250207_170801.jpg Views:	4 Size:	2.84 MB ID:	3566647
                  but when I disconnect the mainboard it blinks and doesn't remain steady:
                    • 12181
                    • U.S.
                    Diagnosing would be much easier if you had the whole tv.
                    • Gjackson
                      • Aug 2021
                      • 134
                      • Malta
                      Just a quick update, I did exactly that and got the whole set to test with. Plugged everything back in and now it works somehow, I have standby and the tv powers on. I'm a little baffled as to why it's now working. Owner said that it was being intermittent but when I checked it there was no standby at all. There seem to be no cold joints and I tried tapping the boards while in operation and they seem to keep working. The only thing i've done is resolder the eeprom and replace the thermal paste on the CPU. Any clue as to what I should check before reassembly?
                        • 12181
                        • U.S.
                        • Gjackson
                          • Aug 2021
                          • 134
                          • Malta
                          I suppose so, in the meantime thanks everyone for the help!
                            • 12181
                            • U.S.
                            You are very welcome, never a problem helping decent people such as yourself.
                              09-07-2024, 05:50 AM
                            • tvguy12012012120
                              by tvguy12012012120
                              02-07-2025, 05:13 PM
                            • ChristianBr01
                              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                              by ChristianBr01
                              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                              04-23-2025, 01:48 AM
                            • Kaar3l
                              Samsung QLED QE65Q7FNAT only standby light
                              by Kaar3l
                              TV: Samsung QLED QE65Q7FNAT
                              PSU: BN4400940A
                              MB: BN94-12832K
                              I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                              09-24-2024, 01:35 PM
                              09-06-2024, 11:40 PM
