LG 37LP1R-ZE,NO 5V IN THE MAINS
  • JRade
    • Nov 2013
    • 28
    • Serbia
    Model:37LP1R//37LP1R-ZE//37LP1R-ZE.ALEWLF
    Power supply(SMPS)-KNP-3371(IDTV6 & DCR)//KNP-3372 (Tornado)//REV:A 05. 3.21
    it is model:KNP-3372//6871TPT315B
    It has an 8-pin IC111 connected to a small transformer T101 in the network,
    which probably gives a voltage of 5V, but the IC is broken and I don't know the label.
    Please if anyone knows the IC111 marking or the schematic of this network.
    Thanks!​
  • JRade
    • Nov 2013
    • 28
    • Serbia
    • nomoresonys
      • 12216
      • U.S.
      Manual there, I think the IC is there somewhere but it doesn't look like they are calling it IC111: https://elektrotanya.com/lg_ml-051a_...wnload.html#dl
      • JRade
        • Nov 2013
        • 28
        • Serbia
        Here is the schematic of the power supply board.
        Can I know which IC111 this is?​
        Thanks!
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Thanks!
          Look at these PWM pinouts...
          • JRade
            • Nov 2013
            • 28
            • Serbia
            I'm waiting for IC, I'll get back to you when I try it.
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • davg
              Home network connection problem
              by davg
              I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
              03-06-2021, 07:13 AM
            • japlytic
              Maximum speed should be marked on network ports
              by japlytic
              I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
              One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
              12-19-2024, 05:04 PM
            • chopduel
              Bad mains power causing TV malfunctions?
              by chopduel
              I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
              Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
              • TV would randomly turn off then back on.
              • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
              • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
              12-29-2024, 03:20 AM
            • harp
              simple win network with optimization issue
              by harp
              simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
              06-23-2025, 11:01 AM
