Vizio Main Board?
  • ivtec
    • Dec 2008
    • 1967
    Vizio Main Board?
    Hi guys:anybody knows if a main Board from a Vizio 32wvl 10A fits on same modle 42vwl 10A!
    i found this Vizio 32vwl model that someone smashed and kicked the Panel display and put it in the side of the street,i opened it up and brought home all the boards,power sup, main board,and one inverter board,
    i know for sure power sup and inverter is not good for 42'' same model but i do not know for sure the main board won't fit.Thanks
  • selldoor
    Slow Learner
    • 7870
    Re: Vizio Main Board?
    Maybe someone will know but as a start have a look on Shop Jimmy they list suitable boards so you could see if the board features for both sets.
    If it does fit the firmware may need some reconfiguration for the larger screen.
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      Today, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
      by JDC
      ONN 100012588
      Issue: No Power, Then Rebooting After Main Board Change
      Short answer: replace main board and power board
      Technical answer: replace main board and Q306 & Q307 on power board.
      Long answer:
      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
