samsung ln46c670m1f won't boot
  • ijchan223
    • Jun 2014
    • 13
    • usa
    Hi, i have a samsung ln46c670m1f that won't boot just a solid red led. i have done some visual troubleshooting and all the caps appear to be good and no obvious fried components.
    tested voltages with the main board disconnected the black light would come on and all the voltages check out on the connector but with the main board connected the standby voltages (at CN8 ) seems to drop and cycles on and off at a rate of 1 hz. to me it appears that there is an issue with the mainboard but i am new at troubleshooting a tv so i would like some input before i spend money on it and it be the powersupply .
  • ijchan223
    • Jun 2014
    • 13
    • usa
    Re: samsung ln46c670m1f won't boot
    Update: i replaced the logic board and it works fine. out of curiosity, i will attempt to do some component level troubleshooting and repair on the board. More than likely the micro-controllers are dead from a lighting strike or something, but you never know till you actually look into it.
    • eigma
      Samsung UN40H5003 boot loop every ~8 seconds
      by eigma
      Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
      Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
      SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
      Main board: BN94-07592P / BN97-08922R...
      11-20-2024, 10:31 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      09-07-2024, 05:50 AM
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • DynaxSC
      ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
      by DynaxSC
      I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
      Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
      Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
      The behaviour is also really very strange, i.e.:
      • The disk shows always up in BIOS - so it is recognized, so far so good
      • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
      02-23-2025, 01:33 PM
