Sharp LC-40E67U Sound NO PIC
  • lilmonk3
    • Apr 2012
    • 259
    Just picked up a Sharp LC-40E67U.. I can get sound on all inputs tested but no pic.. The backlights come on and the screen is glowing bluish black. I would like to try to upgrade the firmware before I dig into this. But not sure how to do it since I cant get a pic to go into the menu... I have the firmware on a usb unziped to the root of the USb. Someone willing to tell me how to do this without being able to do it from the menu??
  • lilmonk3
    • Apr 2012
    • 259
    Re: Sharp LC-40E67U Sound NO PIC
    DONT DELETE .. Got one more question.. I popped the back of and went right to the Tcon.. The TCON has 2 ribbon cables. If I undo the left one, I can get half screen to come up .But if both are connected the screen just glows dark blue/black and I have sound. I cleaned all the contacts and it didnt help. Do you all think its the TCON.. I have not worked on any TVs for awhile and my MM is still packed away in storage from a move.. If you all think its a tcon I will just order one since I can test any of the fuses or anything requiring a MM.
      If you can get half of the screen to come on with normal picture which just one for the cable connected between the T-CON and the LCD panel, then you do have problem in the LCD panel which is not much you can do to fix the panel.
      • lilmonk3
        • Apr 2012
        • 259
        Thanks Bud... After I was thinking about it more last night and dusting off my limited TV repair experience from the past, I starting thing that might be it..
        Time to part it out ..
        • bammbammfran
          • Apr 2014
          • 476
          what happens if you just undo just the right side ?
          • advant
            by advant
            02-03-2020, 12:25 AM
          • AustinComputerDoctor
            Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
            by AustinComputerDoctor
            I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
            I see backlite is active,
            but I cannot get the screen to return back to menus , etc
            This is all after replacing the mainboard...
            any assistance is greatly appreciated.
            03-25-2024, 12:43 PM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • raileanu
            TV SHARP LC-26P50E KD186 QKITPD186WJN3 (WE015169S) need working firmware dump set
            by raileanu
            Hi.
            Please if someone help me with a functional firmware dump for this KD186 QKITPD186WJN3 (WE015169S) motherboard from TV SHARP LC-26P50E.
            I think this motherboard it is found in several models.
            What I need is firmware for the NOR chip SST39VF1682 (IC2003) and for the two EEPROMs 24C64 (IC2002) and 24C32 (IC4501).
            I am especially interested in the NOR firmware because I think it has problems.
            The TV initially came only with the red STB LED on and it did not respond to any commands.
            I checked the power supply...
            07-11-2022, 10:07 AM
