Help ID'ing surface mount fuse
  • johnboy1313
    • Nov 2012
    • 1959
    Picked up an older Toshiba 42HL67US with sound but no picture. I found an open fuse on the master inverter. It's got a 'D' printed on it. I think I've ID'd it as a 0.8A fuse. Am I correct?
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Help ID'ing surface mount fuse
    Pic of fuse. Board number 60.42T01.007-M
    • selldoor
      Slow Learner
      • 7870
      Its a tricky one there are a number of smd fuses with a D on that are 0.25a
      • johnboy1313
        • Nov 2012
        • 1959
        My meter showed about .6A at startup then settled to about .4A
          There is no standard rating for the letter of fuse rating. I put my meter in DC A mode and take the current reading with lamps at its highest brightness, then double up that reading. I will go with 1A.
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            Also measure the size of the fuse. Cause I'm going through that right now. The D def means .250ma. But the voltage that goes through the fuse can vary. But if you get the size measurements you can get a lot closer to the right one. I just ordered two different ones for a inverter fuse I'm replacing. Because mine only has 24v going through it but based off the size of the fuse it matches up with a 125v .250ma littel fuse.
              Please understand that voltage doesn't "go through" anything, voltage is a difference in potential energy. In operating the fuse will see almost no voltage drop across it. The voltage rating of the fuse is the maximum the fuse can safely interrupt at full failure current. It should be set to be higher than the maximum supply voltage in most cases.
              • johnboy1313
                • Nov 2012
                • 1959
                I installed an identically sized 1A fuse and it's back up and running. I even found a working remote in my bin.
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                  TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                  FF Series (Very Fast Acting), 0603 Size
                  Features
                  ● Very fast acting at 200% overload current levels
                  ● Low DCR
                  ● High inrush current withstanding capability
                  ● Fiberglass enforced epoxy fuse body
                  ● Copper termination with nickel and tin plating
                  ● Halogen free, RoHS compliance and lead-free
                  Applications
                  ● Notebook computers and tablets
                  ● Digital cameras
                  ● Memory cards
                  ● Toys
                  ● Bluetooth earphones
                  ● Portable electronic devices​...
                  10-07-2024, 05:50 AM
                  Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-06-2024, 08:10 PM
                  Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                  This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
