Sony KD-55X9000F TCON Issue
  • thelankanguy
    • Oct 2021
    • 9
    • Sri Lanka
    The TV shows a black screen with no image.
    TCON ribbon connectors were disconnected individually for image and there was no half image even.
    Later both ribbons were disconnected and TCON voltages were tested.
    12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
    There is also a short to ground in this circled inductor.
    Is this a TCON issue or something else ?
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    IDK anything about T-Cons but Im trying to learn.
    Is there voltage when the ribbon LVDS cables are connected and video is supposed to be playing?
    Reason i ask is perhaps some circuits only activate when there is actual signal coming in.
    • EazyBone
      • Jun 2023
      • 1352
      • United states
      Did you take a flashlight to the screen and confirm it isn't a backlight issue?
      • thelankanguy
        • Oct 2021
        • 9
        • Sri Lanka
        It's not a backlight issue mate.
        I can see the backlight turn on.
        • EazyBone
          • Jun 2023
          • 1352
          • United states
          Well you didn't say that so we don't know. More data you put the better to assist you.
          • thelankanguy
            • Oct 2021
            • 9
            • Sri Lanka
            Thanks for the reply mate.
            So, I got it fixed.
            Scotch taped the CKV lines in one half and tadaa it's back to life
            The TCON voltages are a bit different when compared to LG panels.
            In this case, VONE and VOFFE doesn't show voltages when both ribbons are disconnected.
            But in the case of LG panels, I've seen VGH and VGL being present even with the ribbons disconnected.
            My initial assumption was the TCON being bad due to the absence of VONE and VOFFE.
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              So, I got it fixed.
              Interesting...how did you know to tape the CKV lines? What reference where you going off of to try this?
              • thelankanguy
                • Oct 2021
                • 9
                • Sri Lanka
                Sorry about the late reply mate.
                Just followed a youtube video which had the exact same issue for a different model. Luckily they both had the same TCON.
                Link: https://youtu.be/FEKBXC_QqkY?list=LL
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • iglitare
                  by iglitare
                  09-04-2025, 07:13 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • remmurdmd
                  Vizio E65-E1 strange image issue
                  by remmurdmd
                  Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
                  10-02-2022, 09:12 PM
                • AK_777
                  Sony KD-65A1 Repair – 4 Red Blinks Error
                  by AK_777
                  Hi everyone!
                  I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                  Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                  02-20-2025, 04:15 PM
