JVC LT-32CA120 service menu
  • intercepter
    • Sep 2016
    • 4
    • Bosna i Hercegovina
    I have JVC LT-32CA120
    Board:Vestel 17MB171
    I need rotate screen.It is possible in service menu and how to enter service menu?
    Thanks.
  • yokoono
    • Apr 2010
    • 502
    1. Have you tried with the MENU 4725 key?.
    2. At Vestel, you cannot return the image from SM
    3. I don't think you can, but try to save the TV panel profile on the stick (with downloadpq.mb171 folder)​
    • intercepter
      • Sep 2016
      • 4
      I find service menu with Menu-advanced options-4725 but no find any option for return image in service menu.
      I try with this metod but no success.
      https://www.badcaps.net/forum/troubl...flip-the-image
      How to get DownloadPq.mb171 from this board?
      • yokoono
        • Apr 2010
        • 502
        Save the panel profile from the TV and post it here to return the image.
        1. Format a stick with FAT32
        2. Create a folder called downloadpq.mb171 on the stick
        3. Turn on the TV and type MENU 4725
        4. Go to USB Options and type OK on the remote control
        5. After 10 seconds you can remove the USB stick and you will have some files on the stick.
        6. You post them here.
        You can try this method but I do not guarantee that it will work. I have not repaired the TV with this motherboard until now.​
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
        • tusiime
          How to access Vizio m652i-b2 service menu
          by tusiime
          The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
          So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
          Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
          09-15-2023, 09:57 AM
        • alltvrepairs
          Jvc Lt-65VU3000 reduce backlight from service menu
          by alltvrepairs
          I have just replaced led set of this vestel tv due to age.
          I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
          Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
          Thanks again....
          09-20-2025, 05:03 AM
        • sohail5307
          I need how to open this Dell service menu option in dell latitude e6420
          by sohail5307
          I need to open service menu of Dell laptops like image in attachment
          Ignore my English
          I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
          01-13-2023, 05:56 AM
        • Daniel Valdez
          Samsung UN70RU7100K halfway bricked after messing with service menu
          by Daniel Valdez
          Dear All,
          FAFO is the correct definition of what happened with my Samsung UN70RU7100K TV, I was trying to change the region to enable samsung plus using the service mode, entered the mode mute 1 8 2 pwr, and started to dig in. Did some changes while having digital TV signal in the back instead of doing it in HDMI standby mode, I remember changing to a region different then mine but also had a different tuner $%&!. After rebooting the TV, it was all gone, now it shows the splash image and then no image at all. If i disconnect the lan cable from the back, a message is shown in the...
          12-06-2024, 06:56 PM
