Panasonic TH-42PX80E ten blinks
  • PowerAmpFreak
    • 977
    • Sweden
    Hioyo!
    Panasonic plasma TH-42PX80E suddenly show ten blinks during start-up.
    As far as I can see, only standby PSU is on generating +5V and +13V.
    It never tries to start up VA/VS supplies.
    Never worked much on Panasonics.
    Advice?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic TH-42PX80E ten blinks
    Disconnect the dual-row plug near the tuner.
    Re-try starting the set up, --with the set I had, it then started up and initialised the panel--however, no picture...
    It proved the panel and drive electronics/PSU were OK in my case....
    TELEFIX
      +13V is low for a PSU that should output +15V, are you sure about that? As sometimes there is a +12V rail derived from it this could trigger a fault.
      • PowerAmpFreak
        • 977
        • Sweden
        Yep, the +15V line reads +13,3V. The +5V line is +4,98V.
        • PowerAmpFreak
          • 977
          • Sweden
          Just found out the PFC controller IC was blown.
          So, probably it tries to startup the LLC a short time to verify and trig the protection.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            There was someone--one of those parts vendors on ebay selling kits for the
            PSU's of PX80's, and in one listing they had all the reference numbers of all the parts....
            Think the kit for 'em was about £40 if I recall correctly....
            edit--
            Here's whats in that kit--
            F401 F402 C443 C444 Q406 R493 R439 R448 R449 R411 IC406 D431 PR402 R436
            The kit-
            http://www.ebay.co.uk/itm/PANASONIC-...item2573e15747
            TELEFIX
              If the PFC bus voltage is low, then it's quite possible the 15V rail won't be able to fully regulate.
              • PowerAmpFreak
                • 977
                • Sweden
                Nah! The +15V line is coming from the standby supply. It operates without PFC, through rectified AC, when the set is in standby.
                  Yes, but not always. It could be that when under full load (such as when the SC and A board try and run, drawing a couple amps total) this could start loading the rail excessively for a low PFC bus.
                  Most supplies are designed so that they are regulated on only one rail which is dominant. In most cases it will be the 5V rail. When the PFC voltage is low, the other rails might drift out of regulation (certain assumptions about the input voltage are normally made.)
                  • Andre Gilbert
                    by Andre Gilbert
                    11-20-2024, 08:52 PM
                  • Biruslapio
                    Panasonic P58V11B 8 and 12 blinks error "fix"
                    by Biruslapio
                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                    04-13-2021, 07:13 AM
                  • jm1234
                    Panasonic plasma TX-P42ST50 - 6 blinks
                    by jm1234
                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                    I checked that board for any obvious faults...
                    05-22-2024, 06:59 AM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                  • CrewmanRedShirt
                    Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                    by CrewmanRedShirt
                    Hello all,
                    As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                    07-13-2024, 11:02 AM
