Samsung LED TV UN55D6000SFXZA Pwr Sup Board BN44-00424A
  • nramo
    • May 2014
    • 9
    Howdy, I am trying to get some information (part#/rating) on a capacitor on the Samsung BN44-00424A Power Supply Board. The capacitor is CP803, it blew out and I'm hoping that replacing it will fix my problem . Thanks for any assistance in advance.
    Re: Samsung LED TV UN55D6000SFXZA Pwr Sup Board BN44-00424A
    That is the high voltage snubber cap for the diode DP801.
    Did it blow up badly that you cannot read any printing on it? Picture of it may help
    http://www.shopjimmy.com/samsung-bn4...pply-board.htm
    • nramo
      • May 2014
      • 9
      Thanks Budm, I'll try to upload a picture later tonight. Yes, it blew up and all that is left is some parts of the blue. There is charring all around it, but none of the other parts seem to have received damage.
      • nramo
        • May 2014
        • 9
        See attached for pics. Looking for part info. Thx.
          Did it blow the fuses on the board?
            Try PM this guy to see if he can look at that cap for you:
            https://www.badcaps.net/forum/showth...24A#post426926
            • nramo
              • May 2014
              • 9
              Thanks, I just sent a PM to the guy, as for the fuse, I'll have to check it out, unfortunately I don't have a multi-meter at the moment but will be sure to check it out once I do.
                I just look at the diagram of BN44-00428B, it has the same setup as your board. That cap is 220pF 1000V.
                I would go for 2000V for more reliability.
                1000V, 5mm lead spacing
                http://www.mouser.com/ProductDetail/...HWvUmA9o8FVeun
                2000V, 7.5mm spacing
                http://www.mouser.com/ProductDetail/...ko6ZFjCEfPc%3d
                • nramo
                  • May 2014
                  • 9
                  Thanks for the info budm and tvtanner. I've ordered the part, will let you know how it turns out, wish me luck .
                  • nramo
                    • May 2014
                    • 9
                    So, just installed the capacitor and had the fuse checked. The fuse was bad, so I went to radioshack and got a fuse, only problem is that the fuse didn't match up exactly. The fuse I got was a glass with low breaking capacity, the one in the circuit card is a ceramic with high breaking capacity. I tried the fuse blew instantly, so I'm hoping that replacing the fuse will solve my problem, no other noted damages. I'll post an update when I get one, let me know if you have any ideas.
                      That means there is shorted out circuit on the board some where.
                      • nramo
                        • May 2014
                        • 9
                        I was thinking that it might mean that, but hoping it was just the wrong fuse. Thanks for the help.
                        • johnk_13
                          • Jan 2015
                          • 12
                          Did you ever resolve this problem? I have the same issue. I was planning to replace the the cap and the fuse. Let me know when you get a chance, thanks!
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4959
                            • New Zealand
                            Just replace them, then you could use the series lightbulb trick to see if there is any more problems, if so then the switching transistor or IC probably blew as well
                            -David VanHorn
                            • johnk_13
                              • Jan 2015
                              • 12
                              This seems like a common problem with these TV's/boards. Can you tell me the component number of the switching transitor and IC that could go bad when this issue occurs? Thanks!
                              • nramo
                                • May 2014
                                • 9
                                Johnk_13, I ended up replacing the board, I got one for a great deal. I didn't have the equipment to properly make repairs to the board. Good luck.
                                • johnk_13
                                  • Jan 2015
                                  • 12
                                  I replaced the PS board and now have power. However there is still an issue and not sure if it's the PS board I installed or something else. So now my UN55D6000 TV has sound but a black screen with images that can be barely seen. Would this be a problem with the Power Supply board or the Inverter boards (left & right). From a youtube video, I unplugged the connector from the main board to the PS board and the screen was still black. I also unplugged the left inverter and still a black screen. I then reconnected the left and unplugged the right inverter and still a black screen. Do you think this is the power board/LED driver? Would you know which pins to measure the voltage of that drive the LED's and what that voltage should be? Thanks in advance.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4959
                                    • New Zealand
                                    Are the inverter boards getting any power from the supply?
                                    Measure all voltages on the connectors to the inverters and post here what they are along with pin names. Include photos of the connectors\boards if you can.
                                    -David VanHorn
                                      It is LED backlights so it does not have Inverter for High Voltage for the CCFL.
                                      So is John is working on the same model TV power supply board or not.
                                      OP power supply board is BN-44-00424A.
                                      http://assets.shopjimmy.com/media/ca...00424a-top.jpg
                                      If is not the same model then he should start a new thread.
                                      "I also unplugged the left inverter and still a black screen. I then reconnected the left and unplugged the right inverter and still a black screen." I like to see the pictures of these two boards and the whole back side of the TV.
                                      • johnk_13
                                        • Jan 2015
                                        • 12
                                        Thanks for the help. Yes it is the BN-44-00424A Power Supply board. Attached are four pictures.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                          09-07-2024, 05:50 AM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
