Panasonic TC-P50U2 - 1 blink
  • TheSMJ
    • May 2014
    A friend of mine sold me his non functional Panasonic TC-P50U2 as is. The TV occasionally work when powered on, but most of the time the set would power on for a couple seconds, and then blink the light once (and repeating that indefinitely).
    Based on the service manual I've seen, this code means the A board needs to be replaced. However I can't get over the fact that the TV does in fact decide to work every so often (albeit rarely) which tells me that a single component may be on the edge of failure.
    Are there any tests I should try to locate a failed/failing component on the board? I'm no stranger to electronics and around a decade ago I used to work in TV repair, but rarely at the component level. I'm excellent with a soldering iron and have access to quite a bit of electrical engineering equipment (and a couple electrical engineers) if it comes down to it.
    • 31199
    Re: Panasonic TC-P50U2 - 1 blink
    if your not new to this then you should know to start wih a visual inspection.
    looking for bad soldering or leaking caps or any signs of exessive heat.
    • TheSMJ
      • May 2014
      I already have. Caps all look fine, and no scorch marks or signs of thermal stress. I didn't pull out a magnifying glass quite yet but all the solder joints look sound.
        1 blink typically A board fault, probably BGA failure. (Like Xbox 360 red-ring, PS3 yellow-light, etc.)
        • TheSMJ
          • May 2014
          On the suggestion of an EE I work with, I pressed down on each of the BGA ICs while powering on the TV and didn't get different results. I may give him the board to re flow the solder anyways.
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
          • nervx
            Panasonic TH-42PZ800 8-blink error mystery
            by nervx
            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
            04-08-2022, 05:19 AM
          • SentraDude
            (Another) 7 BLINK TC-P60VT60 Panasonic - NEWBIE
            by SentraDude
            Greetings from SoCal I am new to this forum but not new to forum world. I come from Automotive end of side which is my main passion in life. Give the automotive nature, I love fixing and restoring things and I have in the past fixed many simple electronics, soldering, etc.. but this is a bit more involved so I found this forum, and I am very glad I did.
            I picked up a Panasonic TC-P60VT60 with the 7 BLINK error.
            Upon removing the back plate I found spider webs, dead spiders, and an amazing amount of dust. I did my best to clean the surface of the boards with a portable vacuum...
            04-04-2023, 04:24 PM
          • rmacintosh
            Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
            by rmacintosh
            I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
            The symptoms of the tv ar as follows:
            • Plug AC in to back of TV
            • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
            • The 3 blink code is given by the power LED
            • If the TV is unplugged and then
            03-14-2020, 12:24 AM
