LG 32lx2r Clicks but no standby light
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Plug it in theres no stanby light, can hear a click from the Power supply
    only voltage what seems to be correct is the 5v stb, all the rest are either non existant or low at the click
    Looking round it seems there are many posts and threads about CAP replacement for the majority of the caps even though they are not bulged or leaking (same with mine no visual sign of bad caps)
    Safe to assume it's a CAP issue? as seen here https://www.badcaps.net/forum/showth...ghlight=32lx2r
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Re: LG 32lx2r Clicks but no standby light
    anyone had similar before?
    • dcapper
      • Dec 2013
      • 496
      I had a similar LG 32" and I had one small cap in the middle of the power supply go bad. It wasn't bulged either. For the price of caps, it's worth a shot to replace. I use simoncapacitor on ebay. He has never sent me inferior caps.
      • anotherdude
        • Feb 2013
        • 488
        • uk
        replaced the majority of the caps, including the small 25v 47uf near the middle of the power supply
        just waiting on 100uf 35v,25v 680uf and 100uf 50v
        but still no ball at the moment those caps should be here tomorrow, hopefully thats it, having spent near £7 already
        • anotherdude
          • Feb 2013
          • 488
          • uk
          replaced all caps, I now have a green light on the set when the click happens the green led flashes red for a split second
          • anotherdude
            • Feb 2013
            • 488
            • uk
            only really significant voltage i'm seeing is 110v around the large cap and heatsinks and other components that side
            not sure if it's a power supply problem or the main board not sending the signal back to the power supply
            any suggestions on testing?
            • ChristianBr01
              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
              by ChristianBr01
              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
              04-23-2025, 01:48 AM
            • GRANDGG
              LG 42lw4500 flashing red light , wight light , 2 clicks
              by GRANDGG
              Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
              05-09-2025, 12:27 PM
            • AleMonti
              LG 55EG910V - no power and no standby light
              by AleMonti
              I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
              I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
              The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
              After checking the basics I did the following:
              • I measured all voltages and as expected the only active supply is the 3.5V standby. It
              11-04-2024, 05:02 PM
            • Kaar3l
              Samsung QLED QE65Q7FNAT only standby light
              by Kaar3l
              TV: Samsung QLED QE65Q7FNAT
              PSU: BN4400940A
              MB: BN94-12832K
              I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
              09-24-2024, 01:35 PM
            • jasonbay13
              Philips 37HFL5682L/F7 no standby light, incomplete service manual?
              by jasonbay13
              picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
              am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
              12-01-2023, 09:55 PM
