Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
This topic has been answered.
  • howardc64
    • Jun 2017
    • 634
    Failure Symptom
    No Display. Just random blocks of grouped vertical red lines.
    Disconnect right 1/2 panel (rear view), left 1/2 displays properly
    Masking T-Con Signal Diagnostic
    Reduced masking to 5 signals on right 1/2 panel and get perfect picture
    Pins are
    1 GND
    2 VGHD
    3 XON
    4 VSSQ
    5 LC2
    6 LC1
    VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
    Pictures and Schematic
    XON, LC2, LC1 are on AUO s302-21 32pin QFN (PDF pg 66 of this HiSense service manual link has pin out)
    Click image for larger version  Name:	IMG_3305.jpg Views:	0 Size:	4.30 MB ID:	3483727 Click image for larger version  Name:	IMG_3304.jpg Views:	0 Size:	2.83 MB ID:	3483721 Click image for larger version  Name:	IMG_3303.jpg Views:	0 Size:	3.27 MB ID:	3483723 Click image for larger version  Name:	IMG_3306.jpg Views:	0 Size:	3.85 MB ID:	3483724 Click image for larger version  Name:	IMG_3310.jpg Views:	0 Size:	3.07 MB ID:	3483722 Click image for larger version  Name:	IMG_3309.jpg Views:	0 Size:	4.21 MB ID:	3483726 Click image for larger version  Name:	IMG_3308.jpg Views:	0 Size:	4.16 MB ID:	3483725 Click image for larger version  Name:	IMG_3313.jpg Views:	0 Size:	3.87 MB ID:	3483732
    Any Better Repair than 5pin Mask?
    3 caps on the lower left rectangle labeled "A" on buffer board are connected to the masked pins. Removing these might produce same repair results. If same, I'll just keep the 5pin mask repair.
    I guess right 1/2 panel higher voltage gate potential line circuit have problems which is why masking them off fixed the TV
    WiFi/Bt also doesn't work
    Service Mode TV Info seems to show no WiFi/Bt HW. But HW is present on the main board. Factory reset and update to latest firmware did not resolve.
  • Answer selected by howardc64 at 10-14-2024, 06:34 PM.
    Diah
    • Feb 2013
    • 6421
    the most common ESD diode got defect as this section
    • Diah
      • Feb 2013
      • 6421
      colored vertical lines always caused by shorted caps
      i would disconnect panel from t-con and start test the suspected caps related to masking of low ohm
      • howardc64
        • Jun 2017
        • 634
        Thanks, I'll check more carefully, didn't find any shorted rails on initial buffer board check. And the 5pin mask solution didn't work long. Once something warmed up, got failure again.
        • Diah
          • Feb 2013
          • 6421
          the wide black line location are the issue at cao
          • howardc64
            • Jun 2017
            • 634
            What is CAO?
            Found 2 caps with low ohm / short to GND on both sides. Removed the cap and low ohm/short is still present. No short on both cap. No other short / low ohm caps on buffer board.
            • Section A, B, C on buffer board are examined
            • Section B y is 5.2 ohm to Section A x. x pin on flex connects to GND on T-Con. Cap is not short.
            • Section C cap pads measure 180ohms without cap. Cap is not short
            • Examined COF in section A,B,C. No burn marks on flex or COF.
            • FLIR video of buffer board shows only hot spots are COF and occasional metal reflections.
            Click image for larger version  Name:	IMG_3317.jpg Views:	0 Size:	1.00 MB ID:	3483841 Click image for larger version  Name:	IMG_3316.jpg Views:	0 Size:	848.8 KB ID:	3483840 Click image for larger version  Name:	IMG_3319.jpg Views:	0 Size:	667.3 KB ID:	3483839 Click image for larger version  Name:	IMG_3318.jpg Views:	0 Size:	679.2 KB ID:	3483842
            • Diah
              • Feb 2013
              • 6421
              Originally posted by howardc64
              What is CAO?
              look on yours keyboards you will see O are close to P LOL.... fast writing
              yours photo which show 180 ohm...they are not caps just 0 coil R --- put them back
              check the area of this section at yours FLIR section
              • Diah
                • Feb 2013
                • 6421
                • howardc64
                  • Jun 2017
                  • 634
                  Click image for larger version  Name:	IMG_3319.jpg Views:	4 Size:	87.5 KB ID:	3483857
                  Thank you much for the hint. Fixed, 2x diode shorts on D14 ESD diodes was culprit. Removed and shorted cap circuit nearby disappeared. TV works with no t-con signal masking. Also found same fix in this thread ( link ) Don't have 4264H ESD diode array ( link from prior thread ) in my donor buffer board pile. Seems unnecessary but probably good to put good one back for ESD protection?
                  4x thermal rectangles in post #6 are just 4x groups copper pads reflections.
                  • howardc64
                    • Jun 2017
                    • 634
                    UPDATE
                    Replacement ESD diode array ( link ) came in. Replace D14. TV continues to work as if it was removed before but now with ESD protection. D15 had no OL issues and works. Was a mistake in prior measurement. Some people claim can remove and put on by soldering iron. Would need a really good micro pencil with a knife tip and probably some low melt solder. I just used hot air station (should protect the gold flex connection below from hot air).
                    These are commonly called TVS (Transient Voltage Suppressor). Note there are other TVS with same form factor and pin out but most are for low voltage high speed communication signals such as USB3 and HDMI. These can't handle > 5-6v. D14 handles close to 30v with VGH so need to get TVS with higher breakdown voltage rating such as the link above.
                    Click image for larger version  Name:	IMG_3360.jpg Views:	0 Size:	755.0 KB ID:	3489098
                    • Diah
                      • Feb 2013
                      • 6421
                      good done to replace it... its not just you write., its belong to gate Transistor for discharge and provide currents linted when the resolution changed-
                      • howardc64
                        • Jun 2017
                        • 634
                        Thanks. So I guess important to replace with correct TVS (Transient Voltage Suppresser for those not reading prior posts) than just remove.
                        Also I guess valuable to salvage buffer boards from cracked screens for spare parts my spare buffer boards were older TVs and didn’t have this particular TVS.
                        • Diah
                          • Feb 2013
                          • 6421
                          exactly this what i did
                          • SS454
                            vizio e650i-a2 backlight flashes then turns off
                            by SS454
                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                            panel: au optronics T650HVN05.4
                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                            08-20-2020, 03:57 PM
                          • mrtek
                            Vizio M65-C1
                            by mrtek
                            Hi.
                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                            07-14-2025, 07:28 PM
                          • jean luc ferre
                            laptop hp g72 b52sf screen problems
                            by jean luc ferre
                            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                            i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                            06-07-2025, 03:27 PM
                          • howardc64
                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                            by howardc64
                            Failure Symptom
                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                            Where is the short?
                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                            05-27-2025, 02:56 PM
