Trying to Save - Samsung UN40MU6300 - No Signs of Life
  • KYBOSH
    replied
    Originally posted by Diah View Post
    you have many programmer software and you put them all in one place... so the DLL will be share in PC register.... as i wrote before clean your PC.. delete all program from the place you or move then other ells,,, download CCleaner and clean Temp and Registery
    It occurred to me that there may be a conflict with drivers/software but I reasoned that the chances of this was slim as they were all based off of the same set of files (I assume).
    I'll try your suggestion and uninstall files and start from scratch. Im not afraid or weary to try these troubleshooting steps out. If anything we will all be more certain of what's what.
    I will try update you guys by tomorrow.
    Thank you all. Great insight.
  • Diah
    replied
  • KYBOSH
    replied
    Originally posted by lotas View Post
    You first need to remove the protection, that is, remove all the checkboxes, click on Write, then erase the chip, then write a dump, check the contents and then install the protection (status registers 0x88, 0x42), and also click Write.
    I did as you instructed. I disconnected the device, restarted the program, changed USB ports, started program with out device attached then reattached the device. It read the same.
    I then went in and unchecked everything in the status register (except for #3) which doesnt seem to be editable even when you try to change it. I redid everything but the QE radio button is still grayed out.
    When I disconnect the device and look at the edit screen again I see the default generic choices.
  • Diah
    replied
    It's strange, but how did you use it, but you probably don't know about registers, this program will show everything without a chip, and you install the chip and look.
    i just show you it work perfectly.. other wise i will never upload to users... there are many tricks. include at the folder Devices --- StatBits.xml
  • lotas
    replied
    Originally posted by KYBOSH View Post
    This is what i have...
  • lotas
    replied
    what are you talking.....? i use this always, no problem at all
    just now also with out adapter plugged in PC
  • Diah
    replied
    QE is not active in this program, it is a clone of the "AsProgrammer" program, in which this function is also not active, where everything works fine is "NeoProgrammer V2.2.0.10", which I posted here.
  • Diah
    replied
    yours problem are at yours PC... plug out yours CH from PC, just run the software... you will be able to choose the spi and edit the SREG
    if you cant then you have Jam at yours pc clean temps etc or use another pc
  • lotas
    replied
  • KYBOSH
    replied
    if you have under it the blocked tricked on theb grayed out-
    do it as this picture.. and try use first read. if its set correct you will need nothings do or do write what ever
  • Diah
    replied
    Sorry for the delay.
    I'm trying to adjust the status as before but the QE radio button under the Status Register #2 is grayed out and uneditable. Everything else is the same ss the previous program. I'm not able to change the status to "42" without this. And i am using the correct chip profile (CL). What to do?
  • KYBOSH
    replied
    you wrote at first post you disconnected MB from PSU and LED come on... this what he mean..
    you need to use this Program SW and choice yours exact 25Q40CL and write it again with lotas file.. no more or less, also don't forget the status to write after you finish
  • Davi.p
    replied
    For me 1 blink is bad ram, i suspect, i have a main board with one bad ram chip, same 1 blink
  • Diah
    replied
    Sorry for the confusion. I used CH314A Programmer v 1.34 by SkyGZ to READ the chip using the BV profile as there was no CL profile available to choose from. I used Lotas' NeoProgrammer to write the fixed file to the chip. The NeoProgrammer has the W25Q40CL profile in it and that's the one i used to write back to the chip. Do you suspect using the software you provided will still make a difference?
    do it again withe program i give here before,, its easy job that you can do it 100 time
  • CapLeaker
    replied
    i do asked at #5 , i wish one of these come under my hand... to investigate deeply just want to know why the SPI sector 0000h - 1000h fly out
    well, I got one... and I am looking at it... I am using it as my monitor and not as a smart TV as such.
  • KYBOSH
    replied
    his problem he Used W25Q40BV because his program SW old one.... i give above the best one which it had W2540CL, that's all
  • Diah
    replied
    Originally posted by CapLeaker View Post
    hopefully it does the trick, as I am having the same TV here. Luckily it still works!
  • CapLeaker
    replied
  • Diah
    replied
    From STBY take a 1k Ohm resistor and bridge it to PSon and BLon. Then plug the TV in. It's a bit far fetched, but I agree with lotas and Diah the MB can't boot for one reason or other. Just wondered what it does if you force it on, as the MB doesn't send any PSon and BLon to the PSU.
  • CapLeaker
    replied
    I am not familiar with this method ...
    Can you pls explain a bit more?
    If you show me how i'll give it a try.
