Trying to Save - Samsung UN40MU6300 - No Signs of Life
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Picked this one up today.
    No signs of life whatsoever. No red led light from the IR module.
    Disconnected the mainboard to see if PSU was working and it was (LED backlights lit up).
    Checked the power button for continuity when buttons were pressed and I got readings.
    Disconnected various components (speaker, wifi module) with no difference.
    Checked mainboard's fuses (found 3) and they were all good.
    I looked on shopjimmy to see what components I may have been missing and I saw that they were selling EEPROMs.
    Then it dawned on me that this maybe exactly what the issue is.
    I have read you guys stories about bad EEPROMs and how the TV would exihibit very strange behavior like remote not working and even complete death.
    What tests would I do to verify i have an EEPROM issue being that the TV is completely unresponsive.
    I actually have an EEPROM reader/writer I purchased when I thought i had a EEPROM problem with the TV but it turned out not to be the case.
    I have included pics. The fuses I have IDd are highlighted in yellow and (what I believe to be) the EEPROM is highlighted in pink.
    Added a higher resolution pic from ShopJimmy for reference.
    I quick search here on Badcaps showed no results for this model TV.
    Thanks in advance
Name:	2024-10-12 23.36.49.jpg
Name:	2024-10-12 23.47.38.jpg
  • lotas
    • Jan 2016
    • 4819
    • Russia
    Look for spi flash Winbond W25Q40CL on the board, read the dump from it and post it here, I will fix it, and you will write it back and your TV will work again...
    • lotas
      • Jan 2016
      • 4819
      • Russia
      Remove the radiator and you will see its serial number is IC1604.
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        Per your request...
        Used W25Q40BV as the chip name bcos 40CL was not an option.
        Thank you Sir
        • lotas
          • Jan 2016
          • 4819
          • Russia
          Originally posted by KYBOSH
          Per your request...
          Thank you Sir
          Try it, don’t forget to set and write status register (0x88, 0x42) after writing dump.
          • Diah
            • Feb 2013
            • 6504
            yes its damaged need to fix... i just want to know why always the sector 0000h to 1000h fly out... which part caused this ?
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              please explain or show me how to do this.
              this is my first time...
              • lotas
                • Jan 2016
                • 4819
                • Russia
                Well, I don’t know what kind of programmer you have, if ch341a, then what program are you using, so I can explain.
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  Yes, CH314A with the CH314A Programmer v 1.34 by SkyGZ
                  • lotas
                    • Jan 2016
                    • 4819
                    • Russia
                    No, this program will not work, it cannot work with the status register, you need to download and install the program "NeoProgrammer V2.2.0.10". And then I will explain how further..
                    • lotas
                      • Jan 2016
                      • 4819
                      • Russia
                      In the program:
                      1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                      2. Click "Unprotect".
                      3. Click "Clear IC" and "Yes".
                      4. Click "Open File" and select your corrected dump.
                      5. Press "Program IC" and "Yes".
                      6. Click "Verify IC".
                      7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE and press "Write" and "Yes"
                      7. Close the program. Ready.
                      • KYBOSH
                        • Oct 2011
                        • 581
                        • Unknown
                        In the program:
                        excellent instructions
                        oy issue is a few things have changed in the versions you are referencing but i am able to follow along.
                        Major problem is with the status register part.
                        Options are totally different from your picture and description.
                        • lotas
                          • Jan 2016
                          • 4819
                          • Russia
                          Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SClick image for larger version
ID:	3483063​RP0, BP1, CMP, QE and press "Write" and "Yes"
                          • KYBOSH
                            • Oct 2011
                            • 581
                            • Unknown
                            Done.
                            Will install shortly and report back.
                            • KYBOSH
                              • Oct 2011
                              • 581
                              • Unknown
                              Not working yet.
                              Red status light is on.
                              When i press the power button on back of TV the status light fliashes once and then no response after that. Display never attempts to turn on. Same when I try with the remote. initial flash of red status light then no more response.
                              i reflashed the chip just to make sure. Status registers confirmed changed.
                              • lotas
                                • Jan 2016
                                • 4819
                                • Russia
                                Well, I don't know, if everything was done correctly when recording the dump, then everything should work, unless there are still problems when they dismantled and soldered the chip back, they didn't move or damage the nearby components (resistors)
                                And yet, before you, no one tried to program this flash drive, I mean, if you have already programmed and downloaded the wrong version of the software, then the TV may behave like that now.
                                • KYBOSH
                                  • Oct 2011
                                  • 581
                                  • Unknown
                                  The previous owner likely didnt try anything relating to the mainboard.
                                  When I picked it up he had a spare power supply which he tried to install thinking it was a PSU issue.
                                  Heatsink also looks like it was never removed until i pulled it off so no way to access the IC.
                                  I have checked the chips read/write function with the programmer and nothing seem suspect about it.
                                  ShopJimmy sells the EEPROM with the firmware preinstalled ($15US) so I may order it and see if that helps.
                                  If anything then i will have a known good dump for the repository.
                                  • lotas
                                    • Jan 2016
                                    • 4819
                                    • Russia
                                    It won’t help, since they don’t know what version of the software you currently have on your TV, in this “MU” series there is no difference what model (number) and what the cost of the panel is (diagonal, manufacturer), the main thing here is that If the software version in 25Q40 and eMMC were the same, with each update via network or usb, the data in 25Q40 also changes....
                                    • lotas
                                      • Jan 2016
                                      • 4819
                                      • Russia
                                      If you had the original dump, then I fixed it for you and it should work, you can also post the t-con dump, it will be 25Q80 and what model do you have, panel number, I’ll check.
                                      • CapLeaker
                                        Leaking Member
                                        • 8349
                                        What happens is you force BLon and PSon with the main board attached?
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                          09-07-2024, 05:50 AM
                                        • Jacksoft
                                          Samsung 225MW EEPROM bootloop
                                          by Jacksoft
                                          I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                          Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                          So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                          According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                          Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                          02-14-2025, 04:18 PM
                                          09-06-2024, 11:40 PM
