JVC LT-50CF890C
  • vinceroger69
    • Mar 2012
    • 6714
    JVC LT-50CF890C
    Hi guys i recently stripped a tv with a damaged panel (screen cracked but showing full image) i sold the mainboard on ebay and the buyer is having a issue with split screen image as in same image on both sides of screen the board i sold him is a identical match any ideas whats causing this as trying to help the person out (his tv works fine with his old main borard his hdmis are damaged)
    MAIN BOARD 17MB170
    lcd number main board came out of VES500QNDP-2D-N43​
    Edit asked buyer for a picture of lcd sticker i think his issue is a lcd and mainboard match problem
    has anyone got the correct firmware he needs?
  • vinceroger69
    • Mar 2012
    • 6714
    Hi guys just a thought is the screen data stored in the eeprom ic if so can they be swapped from board to board (what is the eeprom number on this board ) thanks guys
    • yokoono
      • Apr 2010
      • 488
      1. It has no EEPROM. It only has EMMC. If you have the necessary tools you can change it, but it is quite difficult.
      2. You can use a panel profile, but with 17MB170 I don't think it is possible to save and rewrite the panel profile.
      3. You use a FULL software for the 17MB170 and the TV panel.
      • vinceroger69
        • Mar 2012
        • 6714
        Thankyou yokoono i will let the man know who brought my mainboard from ebay, he will need to find a replacement thats a exact match.
        • vinceroger69
          • Mar 2012
          • 6714
          a question, the board i sold came out of a cracked screen set damaged when moving tv it still showed a full image on screen though, the buyer is now saying the cracked screen has caused a short on the mainboard causing the split screen image in the top picture i am saying its because his lcd screen numbers do not match the tv the mainboard comes out of hes tried a factory re set but cant get past the pairing the remote page is this also a indicator the lcd screen miss match is the cause.
          the 23741628 numbers on each mainboard do match
          • yokoono
            • Apr 2010
            • 488
            Good motherboard worked with other panel code.​ Panel codes are different: VES500QNDP-2D-N43 vs VES500QNDH-2D-N41
            • vinceroger69
              • Mar 2012
              • 6714
              Good motherboard worked with other panel code. Panel codes are different: VES500QNDP-2D-N43 vs VES500QNDH-2D-N41
              the buyer is saying as long as this number matches VES500QN and this number 23741628 he beleived it would be ok do you know what the other number mean after the VES500QN thank you ie the DH-2D-N41 vs DP-2D-N43​
              • bashford59
                bashford59
                • Jan 2025
                • 3
                Hello, I am having the same issue with an RCA 55" TV (RTU5540-B), I recently replaced the main board (AE0012251) since the original board was stuck in a self-diagnostic mode.
                When the TV powered up I received a double image as seen in the attached photo. I tried a factory reset, but that had no affect.
                Any suggestions as to what else I could try?
                • lotas
                  • Jan 2016
                  • 4656
                  • Russia
                  The software does not match your panel, just reprogram the spi flash, as I understand it, your motherboard is LDD.M3458.A138, if so, and if you have a programmer, then you can read the dump from your native motherboard and post it here, I'll try to restore the firmware for you.
                    • 31087
                    you can often change the panel type in the service menu.
                    i have no idea how you get into it before you ask.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • canadaboy25
                      Panasonic TC-P54VT25 No image. A or D board?
                      by canadaboy25
                      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                      The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                      01-17-2021, 01:06 AM
                    • tuner2000i
                      Philips 65PUS8518/12 distorted image after main board replacement
                      by tuner2000i
                      hello everyone,
                      I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                      The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                      07-15-2025, 01:15 PM
                    • huzo
                      Dell 5590 no image on LCD,HDMI works ,the board works...
                      by huzo
                      The board is LA-F411P ,DELL 5590 ...
                      The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
                      02-16-2025, 03:08 PM
