Tnpa5081 af 7 blink error trying to repair
  • ricosavy
    • Jul 2012
    • 457
    • united states
    Re: Tnpa5081 af 7 blink error trying to repair
    I do have some samsung boards i will check see what i have.
    • tw2005
      • Oct 2011
      • 6458
      What about dead Panasonic SC boards of the 2010 era? TNPA5066?
      • ricosavy
        • Jul 2012
        • 457
        • united states
        I have a panasonic tnpa5063 that was given to me to strip parts from to fix the board but the guy was not sure if board is good or not he believes it is no good but i can not find any shorts in it i would hate to strip a board that is good.
        • GuyTV
          • Apr 2014
          • 7
          On EBay some suppliers have kits that include up to 31 components, but none of the kit suppliers show to contain the Q818.
          Where can I get a kit for TNPA5081 with the Q818 transistor.???
          • tw2005
            • Oct 2011
            • 6458
            Find the kit that suits and just get it separate. 2sk3018 on is the code & it's a smaller package or use 2n7002 which is larger but is possible to solder with slight bend of the legs.
            • tw2005
              • Oct 2011
              • 6458
              2sk3018 , KN is the smd code and they're tiny UMT3 package.
              I've never found the right size, and usually end up the next size up which can fit.
              It's one of those ones that may or may not fail. I just have a general rule to replace all that because it's caught me out and beats blowing everything up for the sake of 50 cents
              I have also used 2N7002, just has a higher voltage rating and they've been fine
              • pixelcap
                Pioneer Kuro Pro 111FD 8 red blink error
                by pixelcap
                Pioneer Kuro Pro 111FD 8 blink red LED.
                I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                10-06-2024, 11:26 PM
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
              • nervx
                Panasonic TH-42PZ800 8-blink error mystery
                by nervx
                Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
                Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
                04-08-2022, 05:19 AM
              • sushilachuthan
                APC UPS error P13
                by sushilachuthan
                one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                We replaced the SCR with new device,, but the device is not power on as expected.
                Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                09-26-2025, 09:00 AM
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
