It's nice to have an easy job occasionally...
  • valvashon
    • Oct 2020
    • 91
    While it won't be worth it at all to replace the bulging caps on this Dynex 21" TV, I'm going to do it anyway to keep it out of the landfill. I'll probably end up giving it away but fixing stuff feels good. And yes, I will be replacing all of those PS caps.
    Val
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    I mean it'll cost $2 and 30 minutes of time. Probably worth it. I would also probably give it away free. I give away all small tvs under 50 inches to kids/families also and your right, it's a fun game to fix these things
    • valvashon
      • Oct 2020
      • 91
      Turns out it wasn't that easy of a fix. The caps in the power supply were bad but once replaced all it would show is a lit screen for a moment then it would go dark again. That's the classic bad backlight problem with TV's that have CCFL's in them but fortunately the correct size is on sale for $5 each at the CCFL warehouse. In for a penny, in for a pound and I'll end up with a TV for me or somebody else that will last literally for years with new backlights and legitimate caps in the power supply.
      Dynex!
      • Nugzzy
        • Dec 2024
        • 9
        • Portugal
        WELL Done !!! valvashon
          • 12276
          • U.S.
          Think I would want to inspect/check those ccfl's before this conclusion if you have not already.
          • valvashon
            • Oct 2020
            • 91
ID:	3545048 Click image for larger version
ID:	3545049 Here's a sample of what I found on the CCFL's. This is the top assembly, I've already taken the bottom assembly apart to measure them and they looked about the same. The size I need is on sale for $5 each at CCFL warehouse so this is affordable even though I won't see a return on investment. I've got about $30 into it and will be lucky to sell it for $10 if I don't have to give it away. With new caps and new CCFL's it will probably last forever.
            • valvashon
              • Oct 2020
              • 91
              Finally put this TV back together- they don't make it easy to change out CCFL's do they? This set was significantly more difficult than the Vizio I did a few years ago. Here's what it looks like at startup, you can see some of what I believe is called the halo effect at the top and bottom of the screen (it's currently subbing in for my 50" Samsung which explains the overly large mount):
              Click image for larger version  Name:	IMG_6232.jpg Views:	0 Size:	1.39 MB ID:	3561239
              When there's a picture on the screen it's really not too objectionable. Not sure if this set had this problem originally as it never actually turned on during my time of ownership. This is from the show "Murdoch Mysteries". You can barely see the halo:
              Click image for larger version  Name:	IMG_6231.jpg Views:	0 Size:	2.34 MB ID:	3561240
              Will see if the original owner wants it back, otherwise away it goes!
              Val
              • handsworth
                • Oct 2015
                • 174
                The nicest easiest job I've ever had was I found a 65" Hisense Roku tv on the curb laying on top of a 65" Samsung box. Evidently they bought a new tv and threw out the old one. The tv had a constant reboot and after 1 google research, I found that al it needed was to be reset by pushing a button. Tv worked fine so I gave it to a friend who just rented an apartment and needed a tv. 6 months later, still working fine
