Samsung un55b7000 Vertical Shift
  • DigitalStone
    • Jan 2011
    • 39
    Picked up a samsung un55b7000wfxza. Turns on but has a 1.5 inch vertical shift.
    Its similar to this YouTube video but bit more.
    Opened it up and didn't see any problems.
    Tried reseating all the connections and a picture reset ... no luck.
    Is the the panel or Tcon?
    Anyone have a service manual, seen this before or suggestions on a fix?
    Thank You
  • DigitalStone
    • Jan 2011
    • 39
    Re: Samsung un55b7000 Vertical Shift
    Here is another link with a good video of what the problem is.
      Put TV into standby.
      Press Mute 1 8 2 Power on remote.
      Wait for set to power on. Service menu should appear.
      Access Control > Test Pattern
      Try the various test patterns; including FBE & FRC Before/AfterDDR
      If it is not present on any of the patterns, or only on FRC Before/AfterDDR = Main board
      If it is present on only FRC BeforeDDR and not on AfterDDR = T-con
      If it is present on all three = Panel or T-con
      • DigitalStone
        • Jan 2011
        • 39
        Thank You
          09-07-2024, 05:50 AM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • kotel studios
          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
          by kotel studios
          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
          08-06-2025, 02:07 AM
          09-06-2024, 11:40 PM
