sanyo dp46841 no video or audio.
  • bmmc
    • Nov 2009
    • 13
    no osd.backlights are on but screen is dark.can see backlights on thru holes in back of panel.power supply voltages on the money.green led on at power up but nothing else.set has a digital & analog board.i'm thinking bad digital.any ideas?same on all inputs.
    Re: sanyo dp46841 no video or audio.
    This is a plasma or LCD? If it's an LCD, check the T-con board fuse.
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • ItepK
      Panasonic TX-P42G30E green light blinking, no video, no audio
      by ItepK
      Hey everyone!
      I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
      This post describes my entire troubleshooting process of this TV.
      When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
      I've taken the unit apart, and I've started to check some voltages:
      • On the P11 connector, there is 15V DC only for a brief moment, then it goes
      12-22-2023, 05:06 AM
      HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
      This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
      09-12-2024, 03:36 PM
    • SolarFlare
      Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
      by SolarFlare
      My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
      The TCON board has the following Chips -
      Samsung VTU63A0
      RT6939 - 2nos.
      and all these chips are getting real hot within a minute, I dont know if this is normal....
      06-26-2022, 08:58 AM
