vizio VU42FHDTV10A .. no pic or sound
    Re: vizio VU42FHDTV10A .. no pic or sound
    How about the whole board? Do you hear the relay click when PS_ON is applied?
    It looks like IC801, IC802 are for the PFC, please get the numbers as printed on the top of the ICs.
    • viziodad
      • Apr 2014
      • 19
      • usa
      What threw me is the original & replacement couldn't both be bad, so I looked at other areas, like the pson being too low, and the jimmy website told me it was probably the main board shutting down the ps board.
      Anyway, the ics are:
      IC802 .. 25923 DASD03..extremely difficult to read, and IC801 is almost unreadable.
      • viziodad
        • Apr 2014
        • 19
        • usa
        The resolution on my phone is too poor for the entire board.
        Yes, the relay clicks when plugged in, and when on button on tv is pressed.
          Ps_on of 3.1V is more than enough to turn on the transistor. We need the pin out of the IC so we can check the voltage and the resistance of the ICs. Getting bad replacement board is not uncommon at all.
          • viziodad
            • Apr 2014
            • 19
            • usa
            The chip on both supplies is unreadable..I guess I have no choice but to order another ps board.
            • viziodad
              • Apr 2014
              • 19
              • usa
              #26
              hmm..
              Quote from a similar thread:
              Originally posted by Tetranitrate
              Summary of the problem so far:
              The standby 5v portion of the power supply is functioning correctly, and sending that voltage to the main controller board. The main controller board will respond to the remote / push-button, and send a signal of 3.166v to the PSON, but the main portion of the power supply will only turn on for a fraction of a second when PSON first goes high (I am thinking that the initial voltage pulse to PSON will be a bit higher than 3.166, this can be tested if needed). The main portion of the power supply will turn on for a fraction of a second, and correctly send out 12v and 24v. After a few seconds the 12v and 24v settle down to around 1v. (This is the voltage that is being sent across fuse 1)
              Independently setting the PSON to high with a pair of AA batteries will result in the main portion of the power supply turning on. This sends out a steady 12v and 24v to their rails, where they will remain constant as long as the PSON is being independently driven. A faint sound is heard from the speakers when the main board is correctly receiving the 12v.
              It would seem as though the PSON voltage supplied by the main board is not high enough to tell the power supply to turn on.
              Should my next step be to trace out the PSON pin on the main board, and find out where it should be getting its voltage from?
                The PS_ON is the steady state not pulse, so if the moan board is only the pulse, that will not keep the power supply on. You can easily verify using 2AA batteries to simulate PS_ON but you must cut the wire for the PS_ON that goes back to the main board. One thing I asked earlier is that if you do hear the relay turns on or not.
                • viziodad
                  • Apr 2014
                  • 19
                  • usa
                  #28
                  Yes, I stated above that it does click.
                  I took the ps board with nothing connected except the ac cord, and connected the 2 AA batteries to the PSON pin, and the relay clicked, but still no 24 or 12vdc..
                  I then jumpered the 5vdc standby with a 1k resistor, and got the same results.
                  I think I am now convinced (just trying to eliminate other possibilities) that they sent me a bad PS board, and you are correct.
                  I will order another, and let you know.
                  Thank you much.
                    Ok, I did not see the edited answer about the relay, sorry about that. I hope you can return that defective power supply. I use shopjimmy because it is easy to deal with when I have problem.
                    • viziodad
                      • Apr 2014
                      • 19
                      • usa
                      #30
                      No problem..I got the replacement board from Jimmy, bench checked it to make sure the 12 & 24vdc were there. both good..
                      Installed board, tv came on and worked perfectly, for 2 days..
                      Then the picture flickered, and the tv shut off, except for the white Vizio logo.
                      No 12 or 24vdc again. ..
                      Since the tv worked for a couple of days, I think it's another bad ps board, and notified Jimmy's.
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • ggil44
                        Vizio M65-E0 No Picture, No Sound
                        by ggil44
                        Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                        09-03-2024, 08:30 PM
                      • LEECH666
                        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                        by LEECH666
                        Good day ladies and gentleman!
                        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                        01-19-2024, 05:46 PM
                      • ajshoe
                        vizio E60-E3 backlights, sound, no video
                        by ajshoe
                        Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                        Does this mean remove right side (from front of TV) tabs ?
                        Like a second opinion before possibly destroying set....
                        04-07-2023, 01:59 PM
