Vizio VP50 HDTV10A bad HDMI?
  • Larryokiscout
    • May 2014
    • America
    I have the above model television, I received it third band from a friend when it began failing to power up. After some research, I replaced the caps on the power supply board, and the tv worked fine for about six months. Yesterday I received an HDMI switch with Toslink output to finally hook up all my devices to my surround sound. (The Toslink out on the TV itself has not worked since day one).
    After setting up the switch, and getting everything to work properly, I watched tv for about 30mins then I had to go to work. I powered all the equipment down, and went to work. When I returned home, the only image I had on the TV was a pink square in the center. I reset the power to the system, and now anything put through the HDMI results in either a No Signal message, or a black screen. (Screen is lit, just blank)
    I have removed the switch from my setup, but even if I input the HDMI signal directly from my system into the tv, I still have the same problem. Is this something with the HDCP? Or is the port fried? The board the HDMI is on also contains the analog inputs, and they work fine. I tested my system on another tv, and they work fine there, so I have isolated it to the inputs here.
  • aliougm
    Marantz SR4003 AVR HDMI board issue, seeking for help
    by aliougm
    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
    Connection as below:
    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
    If I bypassed AVR then HDTV screen color be good.
    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
    I replaced all...
    04-30-2022, 12:21 PM
  • japlytic
    Certain DisplayPort-HDMI cables can disable HDMI CEC communication
    by japlytic
    With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
    An examination of the HDMI CEC wiring...
    07-10-2022, 09:48 PM
  • spleenharvester
    Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
    by spleenharvester
    I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
    I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
    03-12-2025, 03:42 PM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • RossMoodley1967
    LG LCD TV HDMI PORT FAULTY
    by RossMoodley1967
    LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
    02-28-2024, 08:38 AM
