Vizio E420vl E420vo panel question
+ More Options
Posts
  • mu2
    • Oct 2009
    • 217
    I have a Vizio E420vl with a good panel and bad main board. I have the opportunity to get a Vizio E420vo with a broken screen but good boards.
    The broken panel in the E420vo is an LG LC420WUG
    The good panel in the E420vl is an LG420WUH
    I would transfer all the boards from the broken panel set to my set.
    Does anyone know if these two panels are interchangeable?
    Thanks,
    Mike
    Re: Vizio E420vl E420vo panel question
    They probably are, but the only way to be sure is if the main boards have the same part # or the T-con has the same part #.
    • mu2
      • Oct 2009
      • 217
      Tom,
      The main boards have different numbers and both sets have the t-con built into the main board.
      Mike
        In which case you are taking a risk; you cannot be certain.
        • ecking767
          • Oct 2009
          • 492
          Vizio E420VL is a 120hz and the Vizio e420VO is 60hz. wont work
          • mu2
            • Oct 2009
            • 217
            Thanks for the info!
            I'll pass on the set with the broken screen.
            Mike
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • howardc64
              Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
              by howardc64
              Failure Symptom
              No Display. Just random blocks of grouped vertical red lines.
              Disconnect right 1/2 panel (rear view), left 1/2 displays properly
              Masking T-Con Signal Diagnostic
              Reduced masking to 5 signals on right 1/2 panel and get perfect picture
              Pins are
              1 GND
              2 VGHD
              3 XON
              4 VSSQ
              5 LC2
              6 LC1
              VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
              Pictures and Schematic
              XON, LC2, LC1 are on AUO s302-21 32pin QFN...
              10-14-2024, 01:30 PM
            • frannyjunk
              Putting LCD panel from Vizio TV into another brand TV
              by frannyjunk
              I have a Vizio P502UI-B1 50" tv and baked the main board a little too much (to reflow BGA) resulting in a dead tv. I would like to use the Vizio LCD panel in another tv. Someone in the P502UI-B1 thread said he/she was able to take that Vizio LCD panel and put it into an LG 50UH5530 and it worked. Looking at the Tcon boards from the 2 tv's show different model boards (LG = EAMDJ2S55 while the Vizio tcon = V500DK2-CKS2). I have since looked up tv's that uses the V500DK2-CKS2 Tcon board (Hisense 50H7GB, Vizio P502-B1E & M50-C1, Westinghouse WD50UT4490, and a few others). Does this mean any...
              07-27-2021, 04:14 PM
            • NSkyLab
              Vizio D43f-J04 is panel dead?
              by NSkyLab
              TV Model: Vizio D43f-J04
              Main Board: TPD.MT5583.PB751 (60103-00876)
              T-Con: BOE_CC430LV2D_43001 V1.0
              Panel: BOEI430WU1
              The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
              This is a dumpster find, don't know if it was hit, there are no visible cracks...
              I though there may be something wrong with the panel voltages.
              Those I managed to find on the T-Con board. Does it seem normal?
              12V: 12.27v
              VCC33: 3.28v
              1.2V: 1.25v
              VGL: -5.87v
              AVDD: 16v
              HAVDD: 7.47v
              VCOM: 7.0v...
              01-29-2023, 08:18 PM
            • edugimeno
              Nevir 39" LCD acting up. Broken panel?
              by edugimeno
              Hi! I got this TV that was supposed to "not work well".
              I turned it on and the BL got lit but nothing was showing on screen
              Opened it and found that the only PS voltages present (12v and backlight) were 100% perfect
              Plugged it back in and the screen kind of started up showing a NEVIR logo but it was split into several chunks with also missing lines in between. Nothing else
              Next time the screen showed an amorphous large color cloud in the screen swinging from side to side (maybe a screensaver picture) with all broken lines everywhere....
              12-15-2022, 10:55 AM
