Samsung LE32C450E1W don't start
  • claudegu
    • Apr 2014
    • 21
    • france
    Hello and sorry for my english, I'm french.
    When I plug my tv, the red light goes on, then if I use the remote to start the TV, nothing happend.
    The power card is a BN44-00338a
    Without the Main board plugged, the backlight goes on
    And I have these values:
    On the CN802:
    1/3/5 : 12,1V
    7/9 : 0V
    11/13/15/17 : 12,2V
    2 : 0V
    4/6/8 : 0v,
    10/12 : 0V
    14/16 : 5,2V
    18 : 0,8V
    CN803:
    1/2/3 0V
    4 : 1,2V
    5/6/7/8/9 : 0V
    10/11/12/13/14 : 24,6V
    On the big capacitor 395V DC
    If I plug the Mainboard to the power board, the back light goes off and the 13V and 5V go up and down and I heard a tik tik about once every second.
    On the big capacitor the voltage goes down to about 320V and up to 390V evrey second too.
    I have tried to remove the mainboard and put loads to the 13V and 5V of the power board, evrery thing is fine with the 13V and the 5V they don't drop.
    I have checked the ampere on the 13V and the 5V between the main board and power board, 400mA on the 13V and 200mA on the 5V.
    If you may help me, I would be very happy.
  • claudegu
    • Apr 2014
    • 21
    • france
    Re: Samsung LE32C450E1W don't start
    I still need help
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Mainboard fault I would think.
      You've proved the PSU and the Backlight systems are working--Not much else left!
      TELEFIX
      • claudegu
        • Apr 2014
        • 21
        • france
        Thank you for the reply.
        About the main board, what should I test ?
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          On powerboard,replace capacitor CM808,very common failure on these...
          Proud owner of dozens of broken TV's and many,many,many boards.
          Our website and passion:http://hollenhundshepherds.com/
          • claudegu
            • Apr 2014
            • 21
            • france
            Hello Martino, thanks for your reply.
            I had a look and find no CM808, I found a
            CP808 22uF 50V is it that one?
            My supply board is a CN07BN44-00338ASE
              As the power board appears to be working there would be little point in doing this.
              • claudegu
                • Apr 2014
                • 21
                • france
                Martino : OK I found it, it is a CMS under the board, just at the output of an opto.
                TOM66: what should I do for the main board, is there some points to test ?
                Thanks for your help
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  I apologize, reading too fast,I thought you had the BN44-00338b,but you have the A version....So ignore my post,Tom66 you stand correct!!
                    the particular fault applies to both 338A/338B and would be correct if the voltages were low or gone, so you weren't too far off.
                    • martino
                      Not so "senior"
                      • Aug 2013
                      • 997
                      • canada
                      The fluctuating 5 and 13volts got me on that. Quickly scanning over the board number sealed the deal for me. Haha.
                      I need to learn how to slow down, not only with soldering at 3am but also reading posts. Lol.
                        • 31198
                        it's a shorted part,
                        start by checking all the diodes, regulators & fets.
                        • claudegu
                          • Apr 2014
                          • 21
                          • france
                          About the CM808, I have removed it, just in case, but nothing happend.
                          STJ: I will do that, but when I plug a 13V and 5V supply on the main board, my supply says: 400mA for the 13V and about 200mA for the 5V so I thought there was no shortage.
                          But is it enough to provide 13V and 5V to the main board to get it "on" ?
                          • martino
                            Not so "senior"
                            • Aug 2013
                            • 997
                            • canada
                            AH!!!....that's how you load checked.....
                            I would put CM808 back in and replace CM801s(see pic,I circled it)....
                            It's 22nF 1000v cap......
                            And you can't just take it out and try,as this cap is sitting in series......
                            • claudegu
                              • Apr 2014
                              • 21
                              • france
                              Martino : my load check isn't valid?
                              OK, I will put back the CM808 and replace the CM801, but I have to get one.
                              • claudegu
                                • Apr 2014
                                • 21
                                • france
                                Martino,
                                Is this one Ok ?
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  Do you have a local electronic hobby store? I see you are in france,the cap is pretty regular,I would be hard pressed if they wouldn't have them....
                                  Take old one with you,always helps Or the france ebay???
                                    I would be surprised if the cap is bad; you can get it from Farnell or probably eBay though (no concern about counterfeits with poly caps, in general.)
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      Tom66. Plz double check before I give him bad advise.( pretty new at this still).
                                      The load test he did was by applying 5 And 13 volts to the main board with an external psu and measured amp draw with that. He didn't "load" the psu itself. Making me think it IS the classic cap fault. I put both schematics beside eachother for location of cm808 and on his that would be the one I stated here.
                                        I think he is using an amp-meter in series with original power board.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                          by ohren
                                          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                          The models launched in 2018 and 2019 respectively....
                                          09-08-2023, 05:24 PM
                                          09-07-2024, 05:50 AM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
