Samsung PS51E450 Plasma Problem.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Re: Samsung PS51E450 Plasma Problem.
    picture as requested Tom.
      OK, as suspected, signals are routed thru that board, so...
      Do you have a couple 100 to 470 ohm resistors?
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        cant remember colour codes Tom. ordered these for another TV would these do ?
          22 ohms, a bit low, should be OK though.
          First with everyhing installed check VS-ON, VS-CON, PS-ON signals, HIGH or LOW? before it starts and then after.
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            Tom triedtesting volts tv on standby got :
            PS ON 3.32v
            PS CON 0v
            VS ON 0v
            tried taking tv out of standby and its not switching on at all. power light just blinks twice every second but voltages above stay the same.
              No screen flash anymore?? Make sure all cables in place....
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                #27
                yes Tom just checked all boards, all cables are in place, no screen flash, different standby LED flashes from yesterday and also control board isn't flashing as much.
                  Well, that's odd, can't explain that. You now have two faults to track down!
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    #29
                    pain in the ass TV lol
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      #30
                      ok tom forgot i took a board out last night and put another in, put original back in and now getting the TV to come one (out of standby) Logic board pattern has changed. i am not getting solid green light for around 4-5 seconds then light going off for 2 seconds then repeating process.
                        Do you get that flash you used to?
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          #32
                          yes tom still get the screen flash.
                            OK please now check the VS-ON, VS-CON, PS-ON signals
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              #34
                              TV switched on Tom getting 0.16 volt for PS-ON but 0v for other 2.
                                Any change in VS-ON as it flashes?
                                • Mikeyboy2007
                                  • Mar 2013
                                  • 745
                                  • Scotland
                                  #36
                                  3.32V when tv is in standby, as soon as the power buttons is pressed it jumps down to 0.16v and no change when flashing logic board.
                                    VS-ON does that?
                                    • Mikeyboy2007
                                      • Mar 2013
                                      • 745
                                      • Scotland
                                      #38
                                      no Tom only PS-ON. other 2 show 0v at all times, TV powered on or off
                                        Huh.
                                        So how visible is this flash on the screen?
                                        Really faint or a bright white "flash"?
                                        I just can't explain how with 0.07V Vs you'd see that. Maybe it's really, really quick! but still, very odd...!
                                        • Mikeyboy2007
                                          • Mar 2013
                                          • 745
                                          • Scotland
                                          #40
                                          Its only part of screen that flashes. Willl take a quick video tomorrow and upload. And yes its realy quick Tom. Its practicly as soon as power goes to tv it trys to come out standby straight away. Flashes then power led starts blinking. When power led stops blinki g it displays nothing on screen and no light on screen
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                            09-07-2024, 05:50 AM
                                          • howardc64
                                            Samsung UN55JU650DF network/streaming problem
                                            by howardc64
                                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                            07-09-2025, 12:44 PM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • bcstedt
                                            Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                            by bcstedt
                                            Just starting to crack into this one and wanted to get the ball rolling.
                                            At power on (plug in), power light on, relays click, repeat (sometimes)
                                            After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                            Removed Y-Main for inspection and testing
                                            This pic from:
                                            PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                            12-15-2023, 10:30 AM
