Sony KDL55EX720 won't turn on
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL55EX720 won't turn on
    Finally, I got to this one.
    The result is very bad. Windex victim.
    Two tabs are corroded and one of them even has a black hole through the tab and into the LCD's PCB, where is missing the trace. Another PCB trace under the tab, it's broken and it is folded up.
    If the PCB would be OK, I would get some ACF tape and I would try a bonding manually. This way, is no point. Where I would find a LCD PCB?
    • Zonambulous
      • Jul 2011
      #82
      The one we just worked on had the same issue, 5 Red flashes.
      Worked through service manual schematics and this thread troubleshooting along.
      Found the corrosion from over cleaning spray.
      Left 1/2 panel worked with only 1 flex cable connected to T-CON, found the charred traces on the panel PCB that was not working.
      Once we cleaned it, and reconnected everything, the panel came on with full picture.
      But only took 15- 20 seconds for bad panel PCB to get hot where the traces were charred,
      then the whole panel started dimming and going back to normal every 2 seconds.
      Disconnected the original working half panel PCB (Left), and re-tested. Right 1/2 of panel displays image now, but dims back and forth.
      Conclusion: Damaged traces from electrolysis. Liquid damage.
      Not sure if we can even get the Panel PCB, and how we would even attach the flex cable to it from the Panel.
      Either way, thank you everyone for information.
      • Abel Bejan
        Sony Vaio does not turn on, overheats
        by Abel Bejan
        I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
        Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
        01-11-2025, 10:11 AM
      • odie34
        Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
        by odie34
        I am a hobbyist (not a professional) so please be gentle...
        I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
        I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
        02-18-2024, 09:11 AM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • Zetabeta87
        Sony KD-49XF809y doesn't turn on
        by Zetabeta87
        Hi everyone!
        I have a 2018 Sony kd 49XF8096 that suddenly stopped turning on: No LED lights up, and it doesn't respond to the power button or the remote control.
        The power supply delivers 19.45vand I simply tried to check the fuses on the 2 boards (power and main) but everything seems ok. I have no references on where to test the voltage, but somewhere on the mainboard I also detect some, so you can't to understand which card may be to blame.
        Can anyone give me some advice? I haven't found anything online
        Thanks so much!!!
        11-04-2024, 03:18 PM
      • Highvoltagerchelie
        Sony XBR-65Z9D won't turn on after lighting strike
        by Highvoltagerchelie
        Good afternoon. I found this forum as I was looking for troubleshooting information for my Sony z9d. A lightning strike hit very close to the house and did nearly $30,000 in electronics damage. The TV appears completely dead with no status light and no picture. I found the Sony XBR-65Z9D service manual and followed the troubleshooting steps on Pages 21-26. All checks seem normal except DC_OFF_DET check on Page 23 R420 voltage was slightly higher than 3V. It was 3.475V and C418 was slightly higher that the 5V at 5.3V.
        I proceeded to check the Power Board CN6401 connector. With all...
        View and Download Sony XBR-65Z9D service manual online. GN2TR CHASSIS. XBR-65Z9D lcd tv pdf manual download.
        11-30-2023, 04:49 PM
