ZSUS trim pot adjust -LG 42PC3D-
  • 120volts
    • Oct 2013
    • 57
    Hello people,
    One of my latest picks LG plasma weak dim picture.
    I replaced 9 swollen caps on PS board and no difference in picture.
    On further investigation I found the ZSUS amp to be shorted.
    I bought a used ZSUS and noticed it has a trim pot on it and I'm not sure if I have to set it.
    Any help is very appreciated.
    Dan "TV Tinkerer"
    Re: ZSUS trim pot adjust -LG 42PC3D-
    The panel sticker contains a voltage list e.g.
    N.A. / 140 / -180 / N.A. / 87
    The last number is Vzbias. That is what you should adjust the pot for.
    To check Vzbias, you probe across the resistors marked with Vzbias arrows.
    • 120volts
      • Oct 2013
      • 57
      Thanks tom I see the arrow for the Zbias
      Dan "TV Tinkerer"
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Check the voltage from ground/chassis to the tab of that transistor, This is the Vzbias voltage--set to what the panel sticker says with the pot on that sub-board.....
        TELEFIX
        • 120volts
          • Oct 2013
          • 57
          Should the bias on the YSUS also be set to the same voltage?
          Dan "TV Tinkerer"
            No, there are two separate adjustments Vsc and -Vy that must be checked:
            Negative voltage is -Vy, positive is Vsc. Measure across the resistors/capacitors labelled.
            • Mcfeetroy
              homemade speakers AN5277 How to adjust the volume?
              by Mcfeetroy
              Hello everyone. I soldered the speakers according to the circuit diagram on the AN5277 sound amplifier microcircuit. Everything works fine (I only added a ferrite ring to remove the sound transmission interference)
              But I can't adjust the sound (there is no variable resistor or something similar for this in the circuit....Please tell me how I can adjust the sound? What needs to be added to the circuit?
              10-27-2024, 10:19 AM
            • gre0013
              Panasonic TC-59R62 Overscan issues. How to adjust?
              by gre0013
              Hello. I need help opening the service menu on a Panasonic TC-59R62
              Its an old CRT with bad overscan. The top left of the screen is cut out and I need to adjust it. Ive tried multiple methods online ie, holding volume down on the TV then pressing recall (with the 30m timer as well). Nothing I have tried has been able to bring up the menu if there's one at all.
              Or is there an adapter I could use to fix this? Trying to use the TV for old retro games but again the top left of the screen is cut out and cant see anything displayed there.
              07-26-2024, 10:14 PM
            • survivalbloke
              How do you trim a BIOS file?
              by survivalbloke
              I downloaded a BIOS file from Lenovo and once I extracted the actual BIOS from the executable, it is 16MB in size, but my IC(Winbond 25Q80DV) is only 8MB in capacity. I have read you can trim the BIOS file with a hex editor but I can't find any instructions on specifically what you will remove.
              04-27-2024, 10:55 AM
            • mikkele86
              Luxman R-5045 - Cant adjust current bias
              by mikkele86
              Hello good people of badcaps.
              im back with another question
              Im trying adjust the current bias accordingly to the manual, but my meter is showing the same value no matter whatever position VR-804a/VR-804b is in.
              DC bias is adjusted and is working as intended.
              Is my settings on the multimeter wrong ? or should i look for a bad component
              note: all transistor are new
              Picture from manual
              My measurements
              04-24-2024, 10:19 AM
            • reessi
              LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
              by reessi
              Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
              Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
              If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
              If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
              12-13-2017, 01:18 PM
