Toshiba 42HP66 no video have sound
  • Shinju
    • Mar 2014
    • 1239
    Hi!
    I have a toshiba 42HP66, has sound but no video. I have not had a chance to take the back off and get pictures and voltage readings.
    Where should I start? I don't hear any Y or X buzzing and I see they both have 4 ceramic fuses.
    Thanks!
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: Toshiba 42HP66 no video have sound
    MY FIRST QUESS WOuld be IPM is bad on y sys. very typical. its a fairly easy repair - buy a new IPM and remove old (google it) and install new. good luck.
    • Shinju
      • Mar 2014
      • 1239
      I tried doing a quick google search but it kept pulling up CoopellTV repair lol.
      Does anyone happen to know the part number off hand for the IPM?
      • capkid
        • Oct 2010
        • 1339
        The IPM part number is usually listed on the side of the large heat sinks. The 42HP66 I'm working on uses YPPD-J018C: http://www.ebay.com/itm/YPPD-J017C-Y...-/110502432151
        Check the white ceramic fuses on each of the sustains. A blown fuse is a typical indicator of IPM failure on that particular board. If you've never replaced an IPM, it is NOT an easy repair for a first-timer. Take your time:
        https://www.youtube.com/watch?v=Y8MNQYXw8E0
        LG Plasma Mal-Discharge Correction Service
        • capkid
          • Oct 2010
          • 1339
          I sent you a PM, also. If you have an ESR meter, can you tell me the capacitance and ESR measurements you receive for the cap at C22 on the Y-Sus's PS101 board?
          • Truncatedhose
            • Oct 2014
            • 343
            I have the same TV here I'm working on with the same symptom. I suspect the Y-SUS, however none of the fuses are bad, which makes me a little doubtful. The IPM heatsink never gets warm, while conversely the Z-SUS heatsink DOES indeed get warm. I would suspect a bad IPM on the Y-SUS, but the lack of a blown fuse makes me wonder. Can anyone offer any help?
            I pulled the Y Drive/buffer out and measured it for shorts, but it seems to be fine. My next step is to pull the Y-SUS and check the IPM for shorts using this guide:
            http://blog.coppelltvrepair.com/2011...s-ipm-for.html
            I will see what I find.
            When the IPM blows, do the fuses sometimes remain intact?
            • Truncatedhose
              • Oct 2014
              • 343
              Okay, so the Y-SUS IPM measures okay in the 6 tests Coppell TV lists. I can't seem to be able to find a problem on the Y-SUS. I pulled the Z-SUS and it's IPM also checks okay.
              If anyone has run into one of these sets with no bad fuses, but symptoms of a bad Y-SUS, please reply! Thanks!
              • soeren
                A2442 - No sound over internal speakers and no video playback
                by soeren
                I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                All happened after the battery ran out of power overall several days when I was on vacation.
                I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                07-26-2024, 01:24 AM
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
                09-06-2024, 05:59 AM
