non brandedset just says 32 lcd ut3219a
  • vinceroger69
    • Mar 2012
    • 6714
    #41
    Re: non brandedset just says 32 lcd ut3219a
    i have just re checked with second meter no ac voltage on outer 2 legs of bridge rectifier mains in on board has 244 volts ac.can you advise what to test next and how if needed cheers guys.
    • vinceroger69
      • Mar 2012
      • 6714
      #42
      some more pictures that didnt attach this morning any ideas guys
        Please take the resistance readings:
        1 & 2
        2 & 3
        4 & 5
        5 & 6
        They should have <1 Ohms readings.
        The solder joints do not look very good.
          My error: you need to check AC on the inside two pins, not the outside two.
          • vinceroger69
            • Mar 2012
            • 6714
            #45
            thanks bud whilst you was looking at this for me i have done some more fault finding l818 is open circuit!! dont know how i missed it can you look at the scheme for me and see what i need to order from cpc i will take the readings for you and post in a few minutes yes the soldering on this board is rubbish it was in a deal on a tv i picked up just thought i would have a go a repairing a badly blown psu and to practice my fault finding and smd soldering we all have to learn somewhere i guess cheers budm / tom im sure once i replace this and tidy the soldering up all will be fine i hope.
              As a quick test, since it is EMI reduction, you can just solder a jumper across it.
              • vinceroger69
                • Mar 2012
                • 6714
                #47
                1@2 00.3
                2@3 13.0
                4@5 12.3
                5@6 00.6
                all tested on 200 ohms setting so i soldered a link across using my bulb tester to save parts with a 1k resistor across the pins tom advised before bulb flashed bright once went out tested all output voltages all spot on as per scheme so thats good now whats the part i need to order i will order some decent solder and remove and reapply fresh solder to the joints done by the previous repairer thanks again for your help guys.
                  Can you cut open that L818 (Differential mode inductor) shrink tubing to what kind of damage it has? As you can see L816 has Thermistor in its place instead of another inductor, you can do without L818.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #49
                    budm if i leave l818 out psu will not start run at all? not sure why as soon as i solder a link across alls fine? l818 has the top bit of wire blown apart 1mm gap i guess probs blown when the thermistor went which i have now replaced some of the readings you asked me to take seem high? tested with 2 different meters just in case are these readings ok? the scheme says its a 22u inductor i cant seem to find one at cpc or on ebay?
                      You have to have jumper in place of L818 (when L818 is removed) because it is connected in series with other component to allow the current to flow all the way to the bridge rectifier.
                      I see TH1, TH2 so 2 & 3 (5 & 6) will be more than one Ohm due to the Thermistors in the ciruit.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #51
                        cheers budm i have just re read what you have wrote so its ok to leave a jumper wire in place (ive used a capacitor lead cut off as a jumper link) so all will be fine now i guess i will re solder and claen up the board many thanks to you and tom for your helpive just realised ive forgot to change c833 capacitor http://cpc.farnell.com/avx/08055c104...0nf/dp/CA07634 as per toms advise ive done all the other bits though are these caps supposed to be fitted ie one side positve and one negitve or dont smd caps matter?
                          That particular cap has no polarity. You'll also notice there are no markings on it.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #53
                            cool cheers tom.
                            • MartijnG
                              Thermistors exceeds critical temperature - HP Elitpad 900
                              by MartijnG
                              When i started my tablet HP Elitepad 900, i go out of nowhere this error: “One or more system thermistors exceeds critical temperature. System will shutdown in 5 seconds…”
                              I didn't change everything and it was running fine before. I cant start my tablet anymore, also in bios/boot option the system shutdowns.
                              Does someone know how to fix this error or where to look at?
                              Model: HSTNN-C75C
                              Motherboard: QPJ80 LA-8781P , SPS: 724353-001
                              Thank you!
                              Greetings,
                              Martijn
                              06-06-2020, 06:23 AM
                            • devheart
                              Samsung PN51F5500AFXZA issue - Power board thermistors cooked?
                              by devheart
                              Hi everybody. I recently acquired this 2013 Samsung Plasma TV, model PN51F5500AFXZA for free because it wasn't working. The red LED just continuously blinks when plugged in.
                              The thermistors on the power board look cooked, with some discolouration of the PCB around them. I've attached an image of the board. The thermistors show as shorted when connectivity tested with multimeter.
                              I tested all the diodes I could see, they all appear working, no shorts. No bulged caps. Nothing else looks shorted or burnt out. The fuse looks fine and tests shorted with continuity....
                              01-02-2017, 05:02 PM
                            • nmbb
                              Can not find Model/Value of Thermistor.
                              by nmbb
                              Machine: Autoclave.
                              Brand/Model: SANYO MLS-3780
                              Manual: (Sorry search option not working on this PDF)
                              Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                              06-02-2022, 05:55 PM
                            • platinumsteel
                              Samsung S20 Ultra Charging Stopped Phone Overheating
                              by platinumsteel
                              Hi guys i have a Samsung S20 ultra (SM-G988U) whenever i plug in my charger it throws a Charging Stopped because phone is overheating and it makes a beeping noise. I have seen that there is a THERMISTOR on the sub board for the charging port and if this is broken or loose in any way the CPU will think something is wrong with the port and throw the error. This happened to me after i was reflowing the tuner IC's on the suboard trying to repair a no service half airplane mode issue I was having. I have already ordered a replacement port and a flex cable. But it will take 2 weeks to arrive but in...
                              02-26-2024, 09:30 PM
                            • Assurance
                              I need help identifying this thermistor
                              by Assurance
                              sorry if this has been posted in the wrong group
                              Im trying to replace this thermistor<<<10D-9 >>>> implies 10ohms, 9mm
                              im not sure if this NTC or PTC ?
                              I need help identifying this thermistor from
                              rs online website and
                              https://uk.farnell.com/w/c/circuit-p...ost=thermistor
                              what will this be an ideal replacement fro RS ?
                              Ive been chatting with RS online but theyve been very unhelpful...
                              06-09-2020, 09:12 AM
