Opinion on 2 tv's
  • dcapper
    • Dec 2013
    • 496
    Opinion on 2 tv's
    Thanks to everyone on this forum, I have successfully repaired about a dozen tv's.
    I recently repaired a Philips PDP 42X3 that only had one bad cap.
    I also repaired a Panasonic TC-P42X2 that I had to replace every board but the buffer boards and the P board.
    I am going to keep one for my cottage.
    I'm into the Philips about $50.00 and about $300 into the Panasonic.
    Both are 720p. Which one would you people keep?
    Re: Opinion on 2 tv's
    Definitely the Panasonic... why did you replace every board?
    • dcapper
      • Dec 2013
      • 496
      I think it was a graveyard tv, where they put dead boards in. I bought the SN and SS from Shopjimmy. and the mainboard from eBay. Would I be safe to keep it? I'm just worried since I replaced so many boards. It is a 600Hz tv unlike the Philips.
      • tw2005
        • Oct 2011
        • 6458
        The SS and SN are likely to be pretty new. Should get some good use out of it, gotta be better than the philips.
          All plasmas are 600Hz driven. Well the Philips might be 480Hz but either way you won't see the difference. Plasma TVs process sub-fields differently to LCD TVs.
          • dcapper
            • Dec 2013
            • 496
            Learned something new. Thank you. Does a panel take a beating when all the boards driving it blow? That's why I'm concerned about the Panasonic.
              Shouldn't do, the panels are basically glass and metal electrodes.
              • tw2005
                • Oct 2011
                • 6458
                Both mine are rebirthed with SC boards, admittedly just the one was shorted. 1.5 and 2 yrs on both still great. they only had 2 -2500hrs on them when I got them.
                • dcapper
                  • Dec 2013
                  • 496
                  Awesome! I guess I'm keeping the Panasonic.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Having one more crack at my 42X20, same as yours. Just scored SN/SS/C1/C2 boards at a good price.
                    If it's still no good after that then that's it.
                    • dcapper
                      • Dec 2013
                      • 496
                      So what have you replaced on that one? You were having the same troubles as I did. I thought I wouldn't get mine working because of the wrong A board.
                      • tw2005
                        • Oct 2011
                        • 6458
                        if i was in the US market it would be easy but Australian A boards are pretty unique.
                        I'd say your A board is not the same one but is the right one, just slightly different features so it was always going to work really. it was all the other surprises I was worried about and you did not disaapoint there either.
                        Does make me wonder if these are a little tempermental when something fails.
                        Mine is a mess really, repaired SS with just the IGBTs, then A board was dead 1 blinker,got a NZ board and rechipped it from my old one.
                        Kind of disappointed i did not know the 1 blink was a single eeprom bad but that's the way it went.
                        somehow blew a DG501 IGBT in the ERC cct on the SN, still not going at this point either, then took a pot shot at the C board and found a buffer IC on that shot, running but picture just maldischarged and I get vertical white band on the C buffer i touched, give it a tap and that goes.
                        Corroded ribbon between the SN and A.
                        Plus it had 8000hrs on it so really my worst Panasonic for a fixer. very high humidity here and who knows what happened to it.
                        Only having a nother go because i have nothing else to work on and seeing yours running, I'm hoping that if i replace all the pnel boards I might get lucky.
                        Anyway should be able to sell the boards if no joy, waste of a panel though if i fail.
                        since plasmas are gone, I'll keep it just in case if I fix it.
                        So essentially all boards except PSU, A board will have a question mark since it was something i attacked and a miracle it still works to turn it on.
                        • Andre Gilbert
                          by Andre Gilbert
                          11-20-2024, 08:52 PM
                        • G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                          by G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                          It does power up when pressing the power button.
                          I already try the power button while plugin the plug with no result.
                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                          Could this be an PSU or eMMC issue ?
                          07-19-2025, 03:43 AM
                        • stecos
                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                          by stecos
                          Hi everyone!
                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                          Having said that I come to the gist of my post on the forum as the title suggests.
                          For my passion for technology I'm now collecting several...
                          11-28-2022, 11:39 AM
                        • AquaMan Ua
                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                          by AquaMan Ua
                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                          05-17-2025, 09:40 AM
                        • double_DD
                          Philips curling iron - is this a common AC cable?
                          by double_DD
                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                          08-18-2025, 10:04 AM
