Samsung TV LE37S81B - Screen refresh problem
  • filli23
    • Apr 2014
    • 4
    • Spain
    I have a Samsung TV model LE37S81B with the next problem:
    I select HDMI 1 as source input (nothing connected in such source) in order to have a black background (this makes easier to see the problem). Then I navigate to main menu, and I remain in such menu 30 seconds. When I change to any sub-menu within the main menu, I can see in the screen a slightly reminder of the text options of previous menu. It is like a shadow of previous menu behind the current one, but such shadow is weak and if I stay without change the menu, the shadow disappear along the time (i.e. 20 to 30 seconds).
    For example, I go to main menu, first option: mode such default option is “dynamic”, I stay during 30 seconds by doing nothing, then I press up key and the menu scroll up (by going to last option of such menu: “reset”) and “dynamic” text remains weakly in next menu's background, by touching nothing it becomes to disappear and within 20 seconds the background where it was “dynamic” text is completely black, as it should have been immediately after I press up key.
    Can anyone help me with this issue? Can it be related with problems in internal power supply? I've reset the TV: Info, Menu, Mute, Power, but the problem still remains, I suppose there is no configuration related with this issue, so probably is a hardware problem.
    Thanks in advance for any help.
  • sordids999
    • May 2013
    • 2161
    Re: Samsung TV LE37S81B - Screen refresh problem
    i had a similar problem with a 22 inch samsung my tcon board was faulty when i used the menu option then changed to anything else i could still see the menu faintly in the background,the same with watching tv there seemed to be a delay but not sure if this is related
      Also of note: Samsung 37" 720p TVs used absolutely rubbish, bottom-of-the-bin LCD panels; usually Chungwha. These do tend to develop image retention issues after some time, as well as mura effect. Unfortunately there is little you can do to fix the problem.
      • filli23
        • Apr 2014
        • 4
        • Spain
        It seems to be the same problem, did you change the tcon board or you fixed it?
        In that case, do you know what kind of defect it had?
        • sordids999
          • May 2013
          • 2161
          I would got with tom on this one his knowledge is far greater than mine
          • filli23
            • Apr 2014
            • 4
            • Spain
            Ok, thanks for your help, I've been reading about this subject and it is clear that there is no way to fix the problem, at least is what I understand.
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • mmccomputer
              problem with replacing lcd screen
              by mmccomputer
              I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
              otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
              If anyone has any information on the subject...
              12-15-2024, 03:44 PM
            • Chrissygizmo
              samsung galaxy ao2s very temperamental after screen replaced
              by Chrissygizmo
              Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
              Ive eventually managed to get it on and working but it's very temperamental...
              The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
              05-26-2024, 12:05 AM
            • jimjoe123
              LCD TV Green/Pink screen problem
              by jimjoe123
              I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
              Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
              Then each time...
              02-23-2020, 01:29 AM
            • Robby-Gr
              TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
              by Robby-Gr
              I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
              However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
              The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
              Additional issues:...
              09-27-2025, 12:02 AM
